Trailer Brake Controler
Old Jul 13, 2005 | 01:35 AM
kennedy's Avatar
Which Brake controler do you guys recommend?
Do they have to be hard wired in all the way back to the plug, or can you plug them directly into somewhere under the dash, like I know you can do with newer trucks.
Thanks.
Old Jul 13, 2005 | 08:06 AM
apwatson50's Avatar
No plug and play for us that I know of. All you have to do is run one wire back to your trailer plug, not too bad anyways, and a power wire to the battery.
As for which one? Any one is better than none, I hear the one with the momentum switch built in is nice forget which one it is. Sorry.
Old Jul 13, 2005 | 08:39 AM
Alec's Avatar
You have to run two wires to the plug in most cases -- one for the brakes, and one for the "charge circuit", a separate wire to its own type I (auto reset) circuit breaker, and a splice into the stop-light switch. The brake switch has way too many wires, if you don't have a diagram, someone here can let you know which is the correct one to tap.
I am using an old Kelsey Hayes hydraulic unit, which I prefer to the momentum type. There is a company called Brake Smart that makes a newer version of this type that uses a solid state pressure sensor in the brake line, instead of my old fashioned spring and bellows type.
If you do use a hydraulic type, the trailer brake tee that you need is 9/16 x 20 threads. You can get it from NAPA -- none of the other places around here carried them.
Good luck.
Old Jul 13, 2005 | 09:08 AM
4x4dually's Avatar
I just traded my Atwood store bough "redline" POS in for a Techonsha Prodigy. Man, it is great. It is still an inertia controlled unit, but it is digital and works ten times better on my 24 and 40 foot trailers. I'm a typical overloader. Last week I hauled a Pettibone loader that weighed 20990 pounds.
Old Jul 13, 2005 | 09:34 AM
Grey Wolf's Avatar
I agree with 4x4dually, Prodigy is one to use
Old Jul 13, 2005 | 09:36 AM
apwatson50's Avatar
Originally posted by 4x4dually
a Techonsha Prodigy..
Thats the one I was thinking of, I know a few people who have those and love them. My truck already had a cheaper one in it and I'm not going to change it for the few times I tow.
Old Jul 13, 2005 | 12:05 PM
Tuckerdee's Avatar
I've got a Tekonsha Voyager, and it's worked just fine for me. It's an inertia/proportional unit. Only reason to spend more money on the Prodigy, I feel, is if you need to brake more axles. Mine is good for 3, and I think the new units are good for 4. The Prodigy has more bells...autoleveling, works in reverse, etc.
Old Jul 13, 2005 | 12:15 PM
kennedy's Avatar
Well, I just bought that Tekonsha Prodigy unit new in box on Ebay, for $75 shipped.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Old Dec 22, 2016 | 11:05 AM
vaughn sexton's Avatar
Trailer brake control
Thanks.
I use a prodigy and love it.
Old Dec 22, 2016 | 02:12 PM
I put a Prodigy P2 (90885) in the crewcab as well.....seems to work very well.
Old Dec 22, 2016 | 07:42 PM
wheelerfreak's Avatar
I'm running the Tekonsha Prodigy as well. I replaced the pep boys unit that the PO had in it with the Prodigy and it is so much better with my various trailers.
Igor
Apr 29, 2006 07:08 AM
Larry R
Aug 7, 2004 08:47 PM
Diesel Fumes
Apr 4, 2004 09:39 AM
Trusty Steed
Jan 29, 2004 03:55 AM
patrick
Mar 11, 2003 06:55 PM
