trailer brake wire for controler
Old Aug 6, 2004 | 02:59 PM
Larry R's Avatar
hi guys, I am in the process of installing a trailer brake controler in my '98 1 ton dually 12 valve truck. My problem is I have found the factory plug in connector under the dash but as this truck did not have the factory tow package the blue wire that would normally go to the 7 pin connector at the rear of the truck doesnt seem to be any where at the rear of the truck, does any one know where the wire terminates after it leaves the plug in connector under the dash. Thanks for any help in this matter
Old Aug 6, 2004 | 09:45 PM
clifford's Avatar
If the 7 pin plug is on the truck the blue wire should be hooked up. If not look under left hand side in the wiring bundles in the back should be there.
Old Aug 6, 2004 | 10:59 PM
Mechanos's Avatar
On my buddies '96, the blue brake wire exited the underdash area through the firewall and was routed with the harness down the frame rail. There was an inline connector in the wiring harness about even with the firewall. The blue wire went into one side of the connector and just terminated there..... no blue wire coming out of the other half of the connector.
Old Aug 7, 2004 | 08:47 PM
Larry R's Avatar
Mechanos,
Thanks for the info! It was exactly where you said it would be and the install went well. Soldering was a pain due to the limited space but the wire is now installed and I now have trailer brakes!
Two beers and a few tie wraps later and my truck is complete.
kennedy
Dec 22, 2016 07:42 PM
Igor
Apr 29, 2006 07:08 AM
Diesel Fumes
Apr 4, 2004 09:39 AM
patrick
Mar 11, 2003 06:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
