Track width on a 93 drw
Old Aug 23, 2009 | 11:38 PM
simplysmn's Avatar
Hey Guy's I am getting ready to go pick up my part's truck in a few week's and need to know guess on curb weight and how long is the wheel base and how wide is track width on a single cab drw 93 diesel I plan on pulling outter dual so it will make it easier to load .Pulling it is no problem I have a 2008 2500 with brake controller just need to know what trailer I need to bring with me
Thank's for the help
Val
Old Aug 24, 2009 | 08:01 AM
RollinCoalSmoke's Avatar
Is this a Dually or a Cab and Chassis? I think the Dually is wider. I will measure my Dually width and length today but mine is club cab so it will be a little longer. If you have a 24' or longer gooseneck you should be in great shape to haul the ole ride home. Good luck.
Old Aug 24, 2009 | 08:09 AM
Midnight Ride's Avatar
My cab & chassis 1ton dually measures out at 20' long, not sure of the width though I know it is narrower than a dually pickup
scott
Old Aug 24, 2009 | 08:17 AM
simplysmn's Avatar
This is a drw pick/up Thank's guy's ad removed
Old Aug 24, 2009 | 09:28 PM
92roughstock's Avatar
Track width, outer dual to outer dual is ~92". That is with 235/85-16 tires.
Weight will be around 5100 for a reg cab, 5500 for xcab. Add 8-900# for 4x4.
Old Aug 24, 2009 | 10:03 PM
simplysmn's Avatar
what is a good guess for inside dual to inside dual ? 80 inches ?
Old Aug 25, 2009 | 08:11 AM
simplysmn my 92 club cab is 20' 6'' end of bumper to end of bumper. Outside rear track width is 92'' inside track width is 52'' give or take a inch or so on the inside track width, didn't crawl under it to measure kinda muddy. Hope this helps ya. Oh and mine weighs 8400lbs with the headache rack, tool box, big stacks, big front homemade front bumper, alot of tools, and half tank of fuel. A 24' gooseneck will work fine, load her backwards to put the weight over the trailer axles and bring her home.
Old Aug 25, 2009 | 08:58 AM
Trebor's Avatar
Dually inner track width for ramps purposes is 49" +/- 1/8" inside shoulder to inside shoulder with 235-85's
Old Aug 25, 2009 | 11:53 AM
jimbo486's Avatar
FWIW, my cab & chassis dually is about 84" outer wall to outer wall.
Old Aug 25, 2009 | 02:07 PM
simplysmn's Avatar
Thank's for all the info guy's she will be commin home middle of Sept if all work's and I will try n post of few pictures of everything .My plan right now is to take the 85 crewcab longbed frame I have and convert it over to 4x4so that way I can have another longbed crewcab I have a 81 shortbed 4x4 that will be used for the body and cross member's then the shortbed frame is going to be turned into a bat mobile for another project my buddy is building for a guy here is some of his work check it out and see what he's done in the past few yr's http://rodneyrucker.com/album/
Val
Old Aug 25, 2009 | 06:47 PM
The sohc motor is awesome. My cousin had one for about 12/14 years and ended up selling it for some big bank. I saw the other day where you can now buy enough parts to build one now. Those engine were pretty B.A. in their day.
Old Aug 25, 2009 | 06:52 PM
simplysmn's Avatar
Yeah the guythat own's all the stuff is a Total Ford Freak has several sohc motor's and also has some colerctor car's has the Eleanor Mustang pretty bad *** car it's self
Old Aug 25, 2009 | 08:51 PM
cannon xpress's Avatar
24' Trailer
fmackey
Aug 6, 2013 07:01 PM
jlipskoc
Mar 7, 2009 08:00 PM
Desertrider33
Jul 29, 2008 10:37 PM
bubbam
May 28, 2008 05:25 PM
Scrambler250
Mar 12, 2004 05:49 PM
