TPS/potentiometer
I have one in my truck. It works fine; I usually don't mess with it. I leave it in one spot; I just used the potentiometer because I didn't want to buy a $150+ sensor.
As for wiring it, just think of the TPS as an upside down potentiometer.
I replaced the Bendix switch (which didn't work correctly like a stock TPS) with a potentometer, while following info found here to install it. It is a linear taper unit like needed, but I really cannot adjust the shift point. It either does or does not shift depending on how it is adjusted, but the shift point is still better than with the Bendix
Worked great for me
and i have had no trouble adjusting it. I made mine shift a little earley.
also I took a vitamin bottle, drilled a hole in the lid, ran the wires through it, siliconed the hole up then hooked all the wires up and put the pot inside bottle and shut her up . has worked for 18 months flawlessly and never got wet. Got pot at radio shack, had a bunch of em' and just clipped wires and put female spades on em'
Mine works fine. I drilled a hole in the dashboard plastic & put the pot in the space under the headlight switch.
I didn't put a **** on it - I want it to stay put. I played with it until I found a setting that has OD come in at 38mph minimum throttle & 55 or so WOT.
Only thing missing is kickdown out of OD, but I can handle that.
Regards, DBF
Regards, DBF
so heres the deal..... i lost my tranny a while back, had a new one put in... ever since i cant get out of third( no overdrive)... I'm told to replace the turbo, i do, it didnt help.... so i check the intercooler. Sure enough it's got some leakage. So while i'm saving up for the new intercooler i read the flash codes in the sticky... I get the code that says my TPS is shorted or open... so i figure i'll try on of those or this potentiometer... Today on the drive home the old girl kicked into overdrive !!
but quickly went right back out.
so whatya guys think?¿?¿?¿?
Potentiometer
Replacing the TPS with a potentiometer is the best move you can make. I did mine several years ago and never a problem. Just remember there is no KICK DOWN out of overdrive when passing at full throtle, use the button.
I used a ten turn linear potentiometer.
Jim
Jim
this is new to me. so please excuse my late questions to this topic.
what is the point of the mod? so you can adjust the shift points? will it work on my truck? can someone please put a link to the sticky if it apllies to me? thanks for the help.
The sticky is at the top of the 1st gen page, go back one level from here and you'll find it.
The TPS is a potentiometer that moves with the throttle. Trouble is, it craps out frequently and costs around $150. Replacing the TPS with a pot allows OD to work again cheaply.
If you're talking about the '01 in your sig, no. It will not work because on your truck the TPS/APPS is the throttle. This will work on any 12 valve truck.
Stop listening to him/them.
