towing auto
towing auto
my father is looking at an 93 truck 2x4 auto stock all around how much can they tow with the auto he now has a 93 with 5 speed going to auto because the shifting kills his back also the auto is an le any input will help like how much you tow with your auto i have an auto but dont tow so cant help him
The automatic towing rating is increased to 14,000# if you add a large fluid cooler with fan to keep the trans cool.
Remember, this is Gross COMBINED Weight Rating - truck & trailer. I tow a 28' fifth-wheel that weighs 7500# with my 92 D250 at 6500#. With the installed heat exchanger on the passenger side of the block, the small cooler above the radiator and the fan/cooler, I had no problem.
The truck will tow more weight with greater reliably, IF you upgrade the trans, etc., etc., etc.
Regards, DBF
Regards, DBF
i pull various wiehgte dloads a lot, nothing huge yet but i have hauled a few 16' flatbeds loaded DOWN with about 5 tons on it and it yanks it good, i wouls think if you just used the OD button and maybe a trans cooler and some pump tweaks w/ guages and a 3200 rpm spring, you couldnt get a truck to pull better! good luck
edonald849
Feb 22, 2009 04:44 PM
