torque spec for...
Old Oct 17, 2008 | 04:11 PM
apprentice's Avatar
torque spec for...
flex plate bolts on 92
Old Oct 17, 2008 | 08:15 PM
apprentice's Avatar
realy, this is a stumper?
no one?
Old Oct 17, 2008 | 09:37 PM
Richie O's Avatar
366 Spring Chicken
OK, OK I got the book out. In my 89 service man it says 101 foot pounds and to use a cross pattern when you snug them up. That is for the bolts that go into the crank. It also says its for a "flywheel" . No listing for "flexplate".
Old Oct 17, 2008 | 09:50 PM
apprentice's Avatar
thanks for the reply.... ive searched and cant find it. was planning on getting things done tonight, guess it'll have to wait for another day
Old Oct 18, 2008 | 12:19 AM
grandpa ralph's Avatar
wait a second..............
from the sticky:
BC's 518 rebuild
https://www.dieseltruckresource.com/...d.php?t=160276
55ft/lbs in star pattern with loctite
Old Oct 18, 2008 | 12:56 AM
Arrow
Hopefully someone more knowledgeable than me can look at this:
from the 92 FSM
pg 9- 99 the flexplate torque spec of 55ft/lbs is at the end of 5.9 gas engine section.
pg 9- 146 thru 148 torque specs for our 12v doesn't list flexplate. It does say flywheel 101ft/lbs
I looked it up because 101 and 55 is a big difference.
Old Oct 18, 2008 | 01:33 AM
ofcmarc's Avatar
from the 92 FSM
Flexplate to crankshaft or flexplate to t/c...
Old Oct 18, 2008 | 02:24 AM
apprentice's Avatar
Bc847's rebuild "I bolted it together with backing-plate, LocTite, and torqued to 55ft/lbs in the typical star pattern."
good enough? gas/diesel should be the same???
will over torque @ say 101ft/lb hurt??
Old Oct 18, 2008 | 02:59 AM
apprentice's Avatar
i don't think you could get a torque wrench in to the t/c bolts... with those i go as tight as i can get them with a std wrench
Old Oct 18, 2008 | 03:15 AM
ofcmarc's Avatar
IIRC you can get to them through the little cover on the pass side of the rear housing. (from the engine compartment side)
Old Oct 18, 2008 | 11:54 AM
apprentice's Avatar
that will make things easier
Old Oct 18, 2008 | 04:18 PM
Richie O's Avatar
366 Spring Chicken
In my 89 FSM I could not find any torque specs for " flexplate " I would assume that the bolts are same grade and thread size between flywheel to crank ( standard ) and flexplate to crank ( auto ) so why wouldn't they be the same torque spec?
Old Oct 22, 2008 | 04:25 PM
apprentice's Avatar
update
went to a friends shop, he has the mitchell repair on line "www.shopkey5.com"
"flywheel/flexplate to engine 101 ftlb"
"12 1/4 torque converter to flex plate 35 ftlb"
"trans to transfer case nuts 35 ftlb"
"converter housing to engine bolts 30 ftlb"
Old Aug 12, 2010 | 01:53 PM
05CTDN8's Avatar
when installing the BD flexplate they say 101 FT/LB. ATS flexplate was 110 FT/LB. And I have re-installed my plate 3 times on the same bolts @ 110 FT/LB. Then the TC @ 35 FT LB. .
