torque spec for...
flex plate bolts on 92
realy, this is a stumper?
no one? |
OK, OK I got the book out. In my 89 service man it says 101 foot pounds and to use a cross pattern when you snug them up. That is for the bolts that go into the crank. It also says its for a "flywheel" . No listing for "flexplate".
thanks for the reply.... ive searched and cant find it. was planning on getting things done tonight, guess it'll have to wait for another day
wait a second..............
from the sticky: BC's 518 rebuild https://www.dieseltruckresource.com/...d.php?t=160276 55ft/lbs in star pattern with loctite |
Hopefully someone more knowledgeable than me can look at this:
from the 92 FSM pg 9- 99 the flexplate torque spec of 55ft/lbs is at the end of 5.9 gas engine section. pg 9- 146 thru 148 torque specs for our 12v doesn't list flexplate. It does say flywheel 101ft/lbs I looked it up because 101 and 55 is a big difference. |
Originally Posted by grandpa ralph
(Post 2246799)
Bc847's rebuild "I bolted it together with backing-plate, LocTite, and torqued to 55ft/lbs in the typical star pattern."
good enough? gas/diesel should be the same??? will over torque @ say 101ft/lb hurt?? |
Originally Posted by ofcmarc
(Post 2246814)
Flexplate to crankshaft or flexplate to t/c...;)
i don't think you could get a torque wrench in to the t/c bolts... with those i go as tight as i can get them with a std wrench |
Originally Posted by apprentice
(Post 2246843)
(Post 2246845)
IIRC you can get to them through the little cover on the pass side of the rear housing. (from the engine compartment side)
(Post 2246297)
In my 89 FSM I could not find any torque specs for " flexplate " I would assume that the bolts are same grade and thread size between flywheel to crank ( standard ) and flexplate to crank ( auto ) so why wouldn't they be the same torque spec?
update
went to a friends shop, he has the mitchell repair on line "www.shopkey5.com"
"flywheel/flexplate to engine 101 ftlb" "12 1/4 torque converter to flex plate 35 ftlb" "trans to transfer case nuts 35 ftlb" "converter housing to engine bolts 30 ftlb" |
when installing the BD flexplate they say 101 FT/LB. ATS flexplate was 110 FT/LB. And I have re-installed my plate 3 times on the same bolts @ 110 FT/LB. Then the TC @ 35 FT LB. .
