Tires for the stock rims
Old Mar 26, 2009 | 09:41 PM
The_Head's Avatar
What other sizes can you run besides 235/85 R16?
Was thinking about getting something taller to get the speedometer to be more accurate.
I also have some weird brand of tire on my truck that I never heard of... Wildcat?
Old Mar 26, 2009 | 09:53 PM
PapeCAT's Avatar
taller on the stock rims would be 255/85 R16.
Old Mar 26, 2009 | 10:02 PM
The_Head's Avatar
Any idea how wide the stock rims are?
I think they are 6.5", but I'm not sure.
Old Mar 27, 2009 | 12:20 AM
Benjamin b2's Avatar
im runnin ford accurides with 255 85 16's, there a 16x7, the stock dodge wheels ive seen 16x7's and 16x6's, if you get your hands on some stock steel ford wheels from the early 90's to 96 i belive, the stock hub caps fit on and they have a center flange which from my expirence, doesnt bend like a dodge wheel on a tire machine. we have about 10 sets on the farm, highly recomend the firestone/ford accuride wheel with a center "flange"
Old Mar 27, 2009 | 12:22 AM
the 255/85/16 is a 33" tire thats 10.00 wide,
Old Mar 27, 2009 | 01:05 AM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
wildcat is a les schwab tire i believe
Old Mar 27, 2009 | 09:51 AM
jesussaves's Avatar
http://www.tirerack.com/tires/tirete....jsp?techid=53
this will tell you what you need to lnow
Im going will 265/75/16 for a little more width
Old Mar 27, 2009 | 10:00 AM
DU.DP.'s Avatar
i like the ford rims also, i have like 10 sets all different widths, i have 6,7,and i believe 8 in widths, easy to find and most likely cheap, go hunt around some, and the 255/85/r16 is a 33, i like 33in tire, clean look for a stock truck
Old Mar 27, 2009 | 01:56 PM
PapeCAT's Avatar
wildcat is the lowest end tire model les schwab sells for our trucks.
Old Mar 27, 2009 | 03:38 PM
The_Head's Avatar
Are they decent enough?
I destroyed my last first gen when a crappy tire decided to shed its tread and blowout.
I keep a much closer eye on tire pressure now. Especially if I am going on a long trip.
Old Mar 27, 2009 | 04:14 PM
PapeCAT's Avatar
My dad had some Wildcat xtx tires on his 2nd gen 245/75 R16 with no problems. I think they'd have more of a disapproval or consensus if they were flawed and weak. Just run em.
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
chw
29
Aug 2, 2006 11:31 AM
UnrulyNFS
Nov 10, 2005 04:25 AM
Timmay2
21
May 7, 2005 12:16 PM
