tips on installing water meth.
Old Oct 8, 2007 | 08:34 PM
ryan10's Avatar
Hey guys, my water meth kit should be coming tomorrow or wednesday. i got the cooling mist 150 psi kit. how hard is the install? i am using my Windshield washer fluid tank. where did you guys mount your pump? also, where did you get a vacuum? i have my boost gauge and my wastegate run off of the port in the block by the intake horn. where should i get the vacuum from for the water meth kit? any other tips on installing a kit are greatly appreciated.
thanks.
Old Oct 8, 2007 | 08:47 PM
Dodge359's Avatar
First off, they dont run off vacuum its triggered by boost. Itapped into my AFC but you dont have one of those so if you're not making copious amouts of boost just T into your w/g line. If you didnt get check valve make sure you mount the pump lower than the nozzles to prevent free flow. Mine is a Snow Performance so it may be different.
Old Oct 8, 2007 | 08:57 PM
ryan10's Avatar
Ok, thanks. i did not order an extra tee, so where can i get one? also, can i just secure the tee with hose clamps? what are the dimensions on the tee i need?
thanks.
Old Oct 8, 2007 | 09:51 PM
Dodge359's Avatar
Whatever size your boost lines are. My box that controls the meth used a tine one so I had to stretch it over an 1/8" barb on the other. Just get a brass t at the hardware store or replace your fitting that your guage is using (at the head) and get a t that screws in there.
Old Oct 9, 2007 | 05:14 AM
ryan10's Avatar
OK, thanks. where are you guys mounting your pumps?
Old Oct 9, 2007 | 09:00 AM
ol' 93 12 valve's Avatar
hey ryan10 what kit did you by and how much did it cost you?
Old Oct 9, 2007 | 09:26 AM
rbrettctd's Avatar
I had my pump mounted on the drivers fender well down low.
Old Oct 10, 2007 | 02:13 PM
ryan10's Avatar
OK, thanks guys. to those of you who used your windshield washer fluid tank for your water meth. did you leave it in the stock position? if so, did you mount the pump over by the tank, or on the drivers side fender? Also, do you tap the injectors into the intercooler piping? or the intake horn itself?
thanks.
Old Oct 10, 2007 | 06:27 PM
ryan10's Avatar
OK, well i am planning on using a T in the wastegate line for to get the boost to my boost switch. can i use vacuum hose for this line or no?
thanks.
Old Oct 10, 2007 | 06:34 PM
Dodge359's Avatar
Yes, unless your making lots of boost. Then silicone is nice. I popped a couple lines before I figured it out.
Old Oct 10, 2007 | 09:59 PM
ryan10's Avatar
I will have about 35 pounds boost. is this too much?
also, if i mount the pump on the fenderwell on the passengers side next to the windshield washer tank will it get too hot from the turbo downpipe?
Old Oct 11, 2007 | 12:48 AM
bigragu's Avatar
Check my gallery pics. I made sure to take pics of the water injection set up in detail.
Old Oct 11, 2007 | 08:13 AM
Dodge359's Avatar
NO, thats not enough to blow hoses off.
jdpiii
Jun 19, 2008 07:34 AM
Ilikebikes
Nov 26, 2006 11:52 AM
Buz
Sep 9, 2005 04:52 AM
Crimedog
Jul 30, 2005 09:20 AM
xj_punk
Jul 10, 2005 06:40 PM
