tiny tach or no?
Old Sep 23, 2007 | 09:31 PM
SmokemS's Avatar
tiny tach or no?
is it cheaper to buy a tiny tach or a tach that hooks into that plug that is suppose to be under the dash of my 93?
Old Sep 23, 2007 | 09:32 PM
rbrettctd's Avatar
Its gonna be more accurately I believe to hook to the one under your dash. Isspro sells the adaptor for their gauges to hook to it.
Old Sep 24, 2007 | 09:36 AM
haloman's Avatar
I have a tiny tach in my 91'. $75 works well in the day but has no backlight for the dark. Its responsive and worked well for me.
Old Sep 28, 2007 | 11:22 PM
SmokemS's Avatar
halo can you take a pic and post where you mounted the censor?
Old Sep 29, 2007 | 09:00 AM
haloman's Avatar
I can but it will be a day or so. I just took some sand paper and sanded the 1st injector line that runs parellel to the grill and mounted the sensor there. I mounted the display at the top of a-pillar.
Old Sep 29, 2007 | 09:24 AM
SmokemS's Avatar
i can wait for the pic....i do appreciate the help
Old Sep 29, 2007 | 09:41 AM
haloman's Avatar
Yea its really easy to install. The hardest part was to decided where to mount the display.
Old Sep 29, 2007 | 09:57 AM
SmokemS's Avatar
i always got a spot for something :-D
Old Sep 30, 2007 | 12:51 AM
dadijohnson's Avatar
tiny tach
I have had a tiny tach for aprox. 7 yrs now. First on my old 84 furd 6.9 and now on my ctd.. The sender clamps onto any injector line. Super easy to install. The digital read out has peel and stick on the back, I mounted mine up against the bottom of the dash stradling the spedo and gauge circle rings, sticky onto the rings. Mounted a small LED light on the flat area of the steering colum pointing at the Tiny Tack. I used a green light and the tach read out is flourecent when the green light shines on it. In this location it is easy to see and still keep an eye on the road One thing to consider is that the sealed internal battery is good for aprox. 5yrs. When it goes out you have to by a whole new unit. Still worth it IMHO.
Dan
Old Sep 30, 2007 | 02:06 AM
SmokemS's Avatar
thank you johnson...i will have to rig something up for the tach......thanks again
SmokemS
May 21, 2008 08:14 PM
ez_lle71
Mar 6, 2008 09:24 PM
rustbucket
Jan 16, 2007 12:02 PM
addededge
Jul 12, 2004 04:18 PM
Farmall
Feb 19, 2003 03:51 PM
