Timing cover seal...
Old Jun 21, 2010 | 01:29 AM
I'm looking to do my KDP and associated bolts, and was looking for a new timing cover seal. Found this one at NAPA...looks like it's a redi sleeve and seal, not just the seal and installation tool/guage.
http://www.napaonline.com/Search/Det...+50022+2022022
Or is there a better seal kit I should consider? I know of the TST and Geno KDP kits but thought I would do it myself.
Thoughts?
Old Jun 21, 2010 | 06:36 AM
Onemoparnut's Avatar
You should only need a crank seal. The cover gasket almost always stays in one piece on the cover. Just use a little silicone and put it right back on. The two I have done I haven't even used the crank seal but it is better insurance to just replace it.
Old Jun 21, 2010 | 11:30 AM
Do I not need the tool and depth guide to install the front crank seal?
Old Jun 21, 2010 | 08:54 PM
Unless your crank is grooved you don't need the sleeve.
Get the kit from Cummins, it has the "tool" you need.
Old Jun 21, 2010 | 10:12 PM
Exekiel69's Avatar
I used the one with the wear sleeve maybe You want to ask the tech at cummins about this.
Exekiel69
Aug 4, 2008 11:43 PM
96RAM
15
Mar 27, 2006 03:58 PM
Geico266
Jan 29, 2006 05:32 PM
mhuppertz
Jan 9, 2006 08:25 PM
Diesel-Dan
May 26, 2004 04:42 PM
