timing???
timing???
need to know how much timing to run with 6x18 injectors with n2o..
im gonna try and finish my trans tomorrow and then borrow some nitrous for this weekend at the drags..
i have an hx40 no afc and the fuel screw at run away..
I'd say put the timing to the head.
IDK about the whole nitrous thing though.... fuel only definely shove it to the head, maybe even advance it a tooth.
I thought nitrous + timing was bad ??
what about bottle pres. and were are you guys sprayin at before or after turbo..
if it holds up for one pass i put it on the dyno see what i can get out of it.. what psi you guys hit it on the dyno..
Is this the truck you were trying to sell?? Anyways I would not go to crazy with timming if your going to add nos. I know my uncle ( in a gasser ) is setting up a msd system that will pull timing out as rpm's increase. I know a gasser is different but I suspect lots O timming and nitrous is not a good thing in either type. I would also make sure to come off the go pedal easy so you don't wreck the turbo. The nos will send that hx in to scream mode. Im going to drag 1/8th mile this weekend. I will be slow and easy as always. Just for fun.
yea its the truck i was selling and its still for sale ill have it for sale down that the track.. yea im thinking the same about the timming. i just hope to get the 47rh done.. and im gonna be running some crazy nos.. so im sure at then end of the day they are gonna have to clean the track.. but i hope to be able to say im the fastes 1stgen.. and a 2wd dually at that..
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
