Time to pull the IP.
Should I be able to get the hidden mounting bolt with a set of metric S wrenches from HF? The IP pours fuel when running. The leak must be from the engine side. I have tried to find it with a mirror without luck so I'll reseal the whole pump and hope for the best.
Here is part one of three on how to remove and replace the VE.
Edwin
Thanks for the advice. I did order the special puller for the gear. I couldn't order the actual wrench for it since I needed the parts and tools on Monday to do the job. That plan is now toast since we are supposed to have stormy weather all next week. Gotta pick up a battery this morning and try to track down the leak. Thanks Jim. I have to run by HF to pick up a set of crowfoot wrenches and S wrenches. I have put off this job all winter since I mostly drive the TDI now, but I want to keep The Brute running right.
Thanks Brian. I'm gonna change all the exterior seals and see what happens. Sometimes it will leak constantly and other times only for a minute or two and then stop. there appears to be a slight leak around the top cover drivers side and I'm thinking it is pouring from the engine side. I'll find out Monday, if the rain holds off.
I have everything loose for pump removal. Just waiting on the gear puller for the IP gear to arrive tomorrow. I really screwed up and crimped the fuel supply line at the IP. Is Cummins 3918641 the correct line for my '89? Hoping the same one fits all 1st gens. Is there a good how to thread for resealing the IP? All the ones I found in the sticky, the pics don't load. Whats the best way to keep the key from falling into the timing cover when seperating the gear and IP. I read to place a towel into the cover which I did for removing the nut and washer, but that is only between the timing cover and gear correct?
To keep the woodruff key from falling out you need to make sure it fits tight in the slot in the shaft. You can stake the shaft next to slot to make it tight.
I use a "C" shape manifold wrench to remove the nuts on the injection pump.
Borrow 2 of the bolts from the grid heater to use on your bar style steering wheel puller to mount it to the pump gear.
You might have to smack the end of the pump shaft to break the tapered fit, leave the nut on and punch it using a brass drift punch.
I turned the engine till the woodruff key is at 12:00 position and stuff a rag between the timing gear and gear case to prevent the key from falling into the case.
Jim Lane or anyone who can help, when I pulled the top cover I thought I heard a metalic click inside (like a spring loaded thingy going to home position). I didn't see a problem so I replaced the gasket and installed the top cover. I think I have rotated the engine plenty for fuel to reach the injectors but nothing is happening. Did I do something wrong with the governer cover? I am sure that the key engaged in the drive gear. Looks like I should be able to pull the cover on the engine. Thanks all.
Quick update. I'm getting diesel and air bubbles from all injector lines no matter how long I bleed them (average cranking around 12 seconds). I've bled all lines at least 4 times. I rebled the pump (1st at the filter, then at the input to the pump and then the pump return line). I then bled the injector lines again. Still getting diesel bubbles. Shutting down for the night.
92smokin blacky
Jun 11, 2009 10:17 AM
PourinDiesel
Competition / Pulls / OffRoad
Jul 21, 2007 12:42 PM
Bobcat698
18
Aug 3, 2006 09:23 PM
