Throttle related problems on 93
Old Jan 13, 2013 | 06:53 PM
Ivy Simpson's Avatar
First, my throttle has begun to only go half way down. Nothing is obstructing the pedal, and the heim joint linkage is adjusted as short as it will get.
Second, my cruise control is VERY erratic - comes on when it shouldn't and doesn't come on when it should. I removed clockspring, cleaned it and tested it and it tests perfect.
Third, my idle is too high even with the heim joint linkage removed. It was perfect ajnd then one day it was too high. I have to put it in neutral at traffic lights.
Arghhh... my 71 year old husband has to use this truck on multiple 1200 mile trips for the next few months!
Old Jan 13, 2013 | 08:24 PM
bobva's Avatar
First -Just a guess cable frayed.
Second ^^^^^^^^^^^^^^
third - Re index your linkage when you cleaned your whatever you assembled it 1 or 2 teeth off. Again still a guess
Old Jan 13, 2013 | 08:31 PM
bobva's Avatar
These teeth
Old Jan 13, 2013 | 08:48 PM
j_martin's Avatar
#2 could be a bad set/coast switch.
Old Jan 18, 2013 | 07:40 AM
I ordered a new cable - came in today. Will install when I get back up to Alabama!
Old Jan 18, 2013 | 07:41 AM
That's what I thought, but I installed a new set/coast switch and got no improvement. Maybe the wires in the steering column?
Old Jan 18, 2013 | 07:43 AM
These teeth
Thanks, but it had been running fine since the pump rebuild and nothing has been disassembled since then.
Kiff
Jun 29, 2009 06:33 PM
dirtygoat
May 31, 2008 04:26 PM
COTMdad
Dec 25, 2007 11:13 PM
JThiessen
14
Feb 5, 2007 10:36 PM
greasy
Oct 22, 2004 10:59 AM
