Is there something wrong with my steering box????
Old Dec 1, 2007 | 01:00 PM
MikeThomas's Avatar
Exclamation Is there something wrong with my steering box????
So, I can drive down the road and one day my steering wheel will be straight, the next nay it will be 30 degrees off to the right and then the next day 30 degrees off to the left. I have the borgenson shaft and a new drag link on there. The bracket it tight on both the box and the frame....so what can it be? Im starting to get a bit worried, any one else have this problem?
Old Dec 1, 2007 | 02:23 PM
HAMMER_DOWN's Avatar
Sounds like you have a sloppy box
Old Dec 1, 2007 | 02:27 PM
BC847's Avatar
1st Generation Admin
Have someone work the wheel while you watch from below to see if you can locate where the slack is.
Old Dec 1, 2007 | 06:13 PM
Dean Snow's Avatar
mine was doing that and what it was, is that the shaft was slipping around the input shaft on the steering box, its hard to notice, but every once in a while you can hear a click from it
EDIT: slide your steering shaft around up and down and try to turn it and see if it slips around the input shaft on the steering box while the truck is off
Old Dec 1, 2007 | 07:05 PM
ChrisLib's Avatar
Ck the rear axle u-bolts/block esp if it`s lifted, I`ve had them loosen up and do that.
Old Dec 1, 2007 | 09:30 PM
Onemoparnut's Avatar
I drove a chevy tow truck that did the same thing and it was caused by the front leaf springs. They were opening up where they curl around the front bushing and that would let the front rear move around.
Old Dec 1, 2007 | 10:36 PM
Fred Swanson's Avatar
Mike, check the pitman arm nut on the box, they can back off there too.
subspd
24
Mar 22, 2007 10:58 AM
MikeThomas
Feb 19, 2007 10:28 PM
unioncreek
Jun 29, 2005 02:00 PM
Jc9995
May 1, 2005 11:48 AM
