tachometer 1991.5
tachometer 1991.5
Okay I want to add a tach. I want to spend the least amount of dollars. What do I need to get. Do I need the one with the alternator pickup or not. My truck is a 1991.5
So with a 92 you can hookup a standard tachometer?
I've been looking into an el cheapo junkyard tach setup. Homemade crank trigger etc. I don't know iff it will work yet.
At this point I'm not spending $100 for a tach
I bought my tach from : www.surpluscenter.com. It is similar to this only 4000RPM model:
http://www.surpluscenter.com/item.as...atname=engines They also have a 5000 RPM model available. I had a local alternator shop add an output wire when I had my alternator rebuilt, but the wiring is pretty simple and can be done easily at home.
Link to adding alt. output
I did a quick search and came up with the following:
http://www.turbodieselregister.com/f...lternator+tach
Hope this helps!!!
Hope this helps!!!
HA ha, I'm so cheap!
Those are some truly wonderful links. It looks like I can have a tach for less than 25 bucks. I could do it for less if I found a VW diesel tach in the pick and pull.
