Tach Help
Old Sep 15, 2007 | 09:59 PM
duracrap's Avatar
Question Tach Help
I bought an electronic tachometer (ametek dixson 700 series)off of ebay. I thought I had connected it correctly to the harness under the dash. I set the tach for 100 hz from the Sender (2 notches in the dampener x 3000 RPM top speed / 60 sec). The tach only reads about 450 RPM at idle. What could cause this inaccurate reading?
Old Sep 16, 2007 | 10:10 AM
What's it read foot on the floor in neutral? These things will idle at 450 RPM, but you can't see out the mirrors.
Old Sep 19, 2007 | 06:09 PM
duracrap's Avatar
That's another thing... Foot to the floor takes the needle back to zero. I stop when the needle goes 360 degrees because I do not want to ruin the guage. There is no smoke at idle, either.
Old Sep 19, 2007 | 06:12 PM
I'd try some other settings.
Old Sep 30, 2007 | 03:36 PM
duracrap's Avatar
THey all make the reading too high or low...None are just right. Settings that seem acceptable lose accuracy when you watch it while you are driving
cuminvsstrokin
Jul 9, 2006 07:50 PM
IBenDCars
Jan 16, 2006 03:17 PM
Paradise Racing
Jun 17, 2004 08:28 PM
97CTD
Aug 14, 2003 03:31 PM
