A/T heat echanger plumbing help PLEASE
OK so the metal tubing from up by the oil filter to the very back of the heat exchanger springs a leak under the clamp holding it to that bracket under the turbo.... rust belt rust at it's finest.
Cut out bad section put in 8" of good 5/8 heater hose no leaks run for 2 days and a new leak from the metal tubing this time in the middle of one of the bends at the rear. nice little pin hole yep more Ohio rust so I won't even try to salvage this tubing anymore.
Now the questions, are these available from the dealer and if so what do I call it to have him order one ?
How do I install this convoluted thing without removing the downpipe etc ?
Anyone ever just ditch the heat exchanger and if so what aftermarket cooler did you install and where ? 'cause the little bitty one by the radiator isn't going to do the job by itself obviously.
If I ditch this will it hurt the trans in the winter I understand the heat exhange goes both ways with the tranny fluid benifiting from heat when it's really cold.
Sorry for the slew of questions but this thing has me flustered and I really need to get it going.
Thanks in advance,
Brian
Thanks in advance,
Brian
I built a new bumper, put a nice big cooler in it and came across a stock under bed cooler and I ditched the one you're having problems with. I have a hard time reaching 180 degrees towing in 100+ degree az heat. Someone else on here has a nice custom underbed cooler as well- there's a lot of room under there on both sides...
IMHO if you add a separate cooler you would be fine getting rid of the water/oil warmer/cooler. We dont have a lockup converter so the fluid not being up to temp isn't a problem.
I know a LOT of guys running twins that ditch it with no ill effects.
Is the water/oil warmer/cooler that cylindrical thing on the passenger side of my engine block? What exactly does it do?
I really wish I had a real "shop manual" for this truck. I've got a dictionary-sized shop manual for my '55 New Yorker and it is absurdly detailed, it explains how pretty much everything on the car works in addition to telling you exactly how to fix it.
I'm liking the idea of aftermarket cooler under bed and remove this thing if for no other reason than to get the space back and I just KNOW the tubing I need will be no longer available.
Way back when I first started spinning wrenches there were chilton manuals man I loved those things, need to find a good set of factory service manuals for the cummins 1st gen as the only haynes I can find is for gassers
Not much of a point to it in say, Texas or Florida for example.
The little radiator type cooler up front is for dumping the excess heat.
Dodge parts counter guy had no clue so I bubba'd it with 5/8 od copper tubing between the two 90's already on there.
Anyone know the dodge part number for the long bendy piece of tubing from the front of the engine to the very rear of the heat exchanger ? Or even have a decent diagram ?
Thanks,
Brian
EDITED so as to show Intercooled truck transmission plumbing.
I hope my pics aren't too big.
# 10 please
#10 is the hunk of tubing that rotted out on me so if I could get that part # for my dodge parts counter guy (and i'm taking this picture with me) that would be AWESOME... man I LOVE this board :-)
Thank you thank you thank you
tswcoaltrain
Nov 12, 2019 09:11 PM
Nevermind.
