PLUMBING FOR AUX. TANK
Old Mar 29, 2003 | 07:17 PM
JARHEAD's Avatar
Want to buy an Aux. tank and plumb it into the truck. Also want to be able to switch between factory tank and the aux. tank. Anybody have any plans on how the best way to do this is??<br><br>Thanks!!!!!!<br>Kip
Old Mar 29, 2003 | 08:19 PM
ejb's Avatar
ejb
Re:PLUMBING FOR AUX. TANK
I like you user name!
Old Mar 30, 2003 | 04:49 AM
pappyman's Avatar
How are you going to mount the tank...1) if its a bed mount then you can just run a hose with a switch shutoff into the current tank fill pipe to keep your main tank full....2) if its a frame mount you would need a switch over valve and plumb into your supply hose to the engine you will also need a in tank pump and a fuel gauge
Old Mar 30, 2003 | 06:25 AM
Big dawg's Avatar
JARHEAD,<br> Check out WWW.transferflow.com. They have what your looking for...<br><br> Big dawg
Old Mar 30, 2003 | 04:33 PM
DHeadington's Avatar
I have an American tank and they have the proper swithover valves and good instructions and what wires to tie into for transfer of tanks and fuel sending units. Check installation instructions. http://www.auxtank.com/auxtank/installation.asp
Old Mar 30, 2003 | 05:16 PM
dieselcrazy's Avatar
just curious here ..... y not just hook into your factory tank and let it gravity feed to keep it full all the time then when your gauge starts to move u know u need fuel . y all the work to add valves etc......... just curious is all .....scott
Mule Skinner
Dec 8, 2012 09:27 AM
firestorm
24
Apr 2, 2011 10:10 AM
CRToney
May 25, 2010 10:09 AM
ROCKHEAD
Aug 9, 2009 12:59 AM
Nevada
18
Mar 10, 2004 10:08 PM
