This is the swap weekend
Old Apr 26, 2013 | 08:55 PM
Bg enemy's Avatar
Finally got the getrag built tansfer case twin sticked now it's time to pull the tired 518 and put the getrag in hopefully every thing goes as planed but with these old things you never know can y'all think of anything with the swap I need to watch out for think I have all the parts need for the transplant clutch master cylinder bracket peadles are the trans crossmembers the same what about drive shafts boath trucks where regular cabs want to use my shafts they have new u joints but have the shafts from the parts truck any helpful pointers would be greatful
Old Apr 26, 2013 | 09:42 PM
93-12Smoke's Avatar
You need the manual fly wheel. Not sure on exact measurements but autos are usually longer than manuals. Make sure you have plenty of slack in both slip joints on the drive shafts.
Old Apr 27, 2013 | 12:39 AM
simplysmn's Avatar
Let us know how well the swap goes I am getting ready to do same thing too a buddies truck and I have a donor truck to rob part's from .
Old Apr 27, 2013 | 07:33 AM
Philip's Avatar
Install the M/C mounting bracket before installing the pedals. With the clutch pedal in. It a 2 wrench job. With the pedal out you can use a ratchette.
That getrag package is 8" shorter than a 518 is. So you need the shafts from the donor.
Old Apr 27, 2013 | 09:21 AM
Smokin$$away's Avatar
BG Enemy im jeoulous that you have the parts to do this. I want to do mine with the Getrag or the NV4500 or even the NV5600 and get away from the slush box. I have a lead on a 4500 but still will have to find the remaining parts. But today im doing my favorite job bahahaha re-roofing my in-laws roof, id rather be bitten by a cobra than do roofing lol. Good luck on your project!!
Old Apr 27, 2013 | 09:45 AM
As Phillp said, you will need to use the parts truck's driveshafts, as the A-518 is a much longer transmission.
I would have a new pilot bearing, a throw out bearing and some transmission mount rubbers on hand at least before pulling the truck apart for the swap.
Depending on if you have a lift on not, mounting the trans first
then the T-case separately might be easier to handle if your working on your back.
If you have a shop with a lift and trans jack, mounting them together is easier.
Old Apr 27, 2013 | 05:22 PM
Bg enemy's Avatar
Thanks for the input guys as of now all the inside parts are in have all new hydrolics polit bushing and all the goodies to go with it tomarrow is the heavy lift day
Old Apr 27, 2013 | 05:26 PM
Bg enemy's Avatar
Smoking it was cheaper for me to find a parts truck instead of one pice at a time gave 2000 for the parts truck and drove it home
Old Apr 27, 2013 | 05:27 PM
Good deal BG enemy. What transfer case you using? The donor truck one or your original?
Old Apr 27, 2013 | 06:55 PM
thrub's Avatar
would be easier to use the donor transfer case as the splines are different between auto and manual.
Old Apr 28, 2013 | 06:40 AM
That is correct Thrub.
The Auto NP-205 is 23 spline.
The Manual NP-205 is 29 spline.
Good luck today with the trans bench pressing game...I have been there before
Old Apr 28, 2013 | 01:20 PM
Bg enemy's Avatar
Well finally got done at 3 am last night would have been sooner but couldn't get the salve cylinder to bleed out so I put the factory one in it that had a bleeder screw in it but I am surprised how much better the truck runs now I guess the auto must of been on its last leg but am glad I did the swap
Old Apr 28, 2013 | 03:46 PM
The way i was taught to bleed slave cyl that had no bleeder was to hook them up fill em up then push/pull the slave cyl a few times then wait a min or 2 then repeat. Worked every time. The old international trucks were the worst. Glad to hear you got it finished. I figured that gear box was better than slush box with less drag ect.. Keep us informed how it does!!
Old Apr 28, 2013 | 10:18 PM
td3620's Avatar
yap it went very well.
Old Apr 29, 2013 | 08:55 AM
93-12Smoke's Avatar
Td3620, was that you with BG at the races a couple weeks back? I was taking to so many people that day i don't remember who all i met.
