Sucked my BHAF into the turbo
Old Aug 6, 2020 | 08:34 PM
mhuppertz's Avatar
Now I need to upgrade I guess. The current turbo is a Stage 4 hybrid H1C with a 16cm exhaust housing. If I remember correctly it is a 60mm compressor.
Any recommendations for a step up, and where to buy it?
Old Aug 6, 2020 | 08:45 PM
edwinsmith's Avatar
How the heck did THAT happen?
Old Aug 6, 2020 | 09:00 PM
mhuppertz's Avatar
Don't know, never seen it before. Was jamming it onto the freeway and then it just cut power. Though I blew a boot, no such luck.
Old Aug 7, 2020 | 07:51 AM
nonrev's Avatar
Super Moderator
10 Year Member
Looking at the pic you can see rust on the screen, that dry filter got wet which in turn weakened the paper element (as well as allowing more dust to cling to it and turn to cement) I'm real surprised that the screen cage wasn't deformed. That's one reason I always run a filter minder on mine. JMHO
Old Aug 7, 2020 | 07:54 AM
Fordzilla's Avatar
Could the airflow be so restricted by the filter being dirty that the structural integrity of the filter collapsed under the suction from the turbocharger?......Ben
Old Aug 7, 2020 | 10:03 AM
cougar's Avatar
I better check mine. I also have an Outerwears pre filter. How much boost were you pushing? I hit 45 psi easy. My H1C has a GDS 60mm compressor side and a 16cm2 exhaust. Not enough air for my IP and injectors. GDS offers a 62mm compressor upgrade. I'm thinking of going that way, but I'm not convinced it will be enough. https://www.gillettdiesel.com/catalo...ocharger-Parts
Old Aug 7, 2020 | 10:07 AM
mhuppertz's Avatar
40 PSI, POD injectors, cut cone, etc.
Old Aug 7, 2020 | 12:27 PM
bannerd's Avatar
I took mine off and it looks clean, mine has metal mesh inside the filter.
Old Aug 7, 2020 | 02:08 PM
edwinsmith's Avatar
I have a K&N on mine. I don't remember if it has a metal screen on the inside. It seemed pretty sturdy. I'll have to check when I get a chance. Probably when I get around to downgrading my A/C to use R12 like God intended.
Edwin
Old Aug 8, 2020 | 06:51 AM
BHD's Avatar
BHD
I have been running the HX35 with the waste gate shut on my stuff. I don't know how they compare to your custom H1C set up, but I think they are hard to beat for the price.
Old Aug 13, 2020 | 05:15 PM
1972RedNeck's Avatar
HX35 is good, but unless it was free, an HE351CW is even more bang for your buck.
I like my free HX35, but when I find an HE351CW, it will be going by the wayside.
Old Aug 13, 2020 | 05:18 PM
mhuppertz's Avatar
I decided to go max effort on my H1C, 62/86mm (biggest you can go with this series), 7 blade wheel, sticking with my 16cm exhaust housing with factory turbine. Comes back tomorrow!
Old Aug 13, 2020 | 06:43 PM
edwinsmith's Avatar
What's the difference between an HX35 and a wH1c and an HE351CW? I have the wH1c on mine adapted to the stock crossover. No intercooler.
Edwin
Old Aug 13, 2020 | 07:49 PM
mhuppertz's Avatar
Edwin
Old Aug 14, 2020 | 11:02 AM
maybe368's Avatar
Edwin
It's probably in the clip, but it's the cw that means clockwise rotation, correct?...Mark
that_guy
Aug 3, 2011 11:06 PM
Kansascrewcab76
Aug 1, 2011 05:26 PM
RSWORDS
Mar 10, 2009 12:45 PM
PourinDiesel
55
Dec 17, 2008 07:51 AM
getblown5.9
18
May 11, 2006 08:09 AM
