Stud Choices
Old Jan 14, 2011 | 07:11 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
Stud Choices
I'm getting ready to spend the coin for the big HP, one item on the shopping list is obviously studs. I see standard ARP's, high tensile ARP's, ATS studs, A1 studs, and A1-HD H11 studs. prices go from 400ish to 800ish.
I've heard debates about grinding valve covers for ARPS vs A1's, whats the story with that?
I plan on running a 62mm s300 single, so i think i can skip the high tensile stuff.
Thanks
Old Jan 14, 2011 | 07:28 PM
92smokin blacky's Avatar
I think just a set of standard ARPs would be fine. Check out BBD diesel they seem to have the best deal i could find.
huntinguy's Avatar
I was just reading something on compD about studs breaking. It sounded like it was happening a lot.
Old Jan 14, 2011 | 07:32 PM
#2isgreen's Avatar
I've never heard about the ATS's until my google search tonight. anybody know anything about them?
does the breaking have to do with not bottom tapping properly?
Old Jan 14, 2011 | 07:35 PM
huntinguy's Avatar
I don't know. It was on 2'nd gen trucks.
Old Jan 14, 2011 | 07:43 PM
My friend got ATS ones for his 24 valve, he said he wasn't sure what brand they were but he said it didn't have ATS's name on them. Said it came with ARP lube though. I'm guessin they were A1s but not sure.
Old Jan 14, 2011 | 07:50 PM
#2isgreen's Avatar
the two things i've heard about grinding are:
A) grid a bit out of the inside of the valve cover
B) grind the rockers
one of these options sounds easier than the other, but which goes with which brand of studs?
Old Jan 14, 2011 | 07:52 PM
grinding of rockers is ARPs and grinding the Valve cover webbing is with the A1's.
Old Jan 14, 2011 | 08:15 PM
#2isgreen's Avatar
A1's sounds easier
Old Jan 14, 2011 | 08:37 PM
fatt's Avatar
If I ever feel the need for studs I'm going to get A1. I've seen broken ARP's on CompD several times. That and the fact that ARP calls for machining the rockers (NOT grinding) makes that an easy decision for me. And BC847 runs A1's
Old Jan 14, 2011 | 08:41 PM
jimbo486's Avatar
I know with ARP's you're supposed to machine the rocker pedestals. They mention that and give specs in their install instructions which are available on the website.
I've heard nothing but good about Haisley's A1's and H11's though.
Old Jan 14, 2011 | 09:01 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
ARP's were a fairly easy choice for me. Cheaper, come with bolts for the rocker pedestals, arp makes 99% of the professional racing hardware and machining rockers is free when you can do it yourself.
I bet most failures are because of installation problems (aka people are stupid). There are a lot of sets of ARP's out there compared to a1's so its hard to compare that. Ive seen failures on a1's in drag racing so its not like either of them have perfect track records.
Whatever you do, bottom tap!
Old Jan 14, 2011 | 09:23 PM
#2isgreen's Avatar
your set up looks pretty close to what i'm aiming for. did you get your 5x16's from SDX? hows the 12 cm housing with those sticks?
I found A1's for $460
can anybody beat that?
Old Jan 14, 2011 | 09:25 PM
no i got them from lee jesse. i cant say much about the 12cm housing, i dont have a drive pressure gauge. it spools like nobodys business.
i dont want to look like "the arp guy" but you can get arps for 400 and spend 60 dollars machining the pedestals. i think its a catch 22 either way.
74dart
Jul 7, 2007 07:58 PM
lil jim
Apr 8, 2005 03:40 PM
ddestruel
Nov 16, 2003 01:54 AM
COYOTE556
Jun 22, 2003 07:51 PM
atc250r
Dec 20, 2002 07:32 PM
