Stomp?
Well I left Friday morning about 0830 hours and got up to Oregon at 1400 hours. I took the pump off my spare motor so I had some extra parts if we needed them and headed into the shop. I pulled in and started taking my pump off my pickup while the spare was in the parts washer. Got it off and started disassembling both pumps. Since all of the parts in the pump that was on my pickup were new we used it and put the KTA head/rotor in it. We stopped at around 1900 hours and went home to get something to eat and have a few more beers. We made it back to the shop at 0800 hours and completed the build up of the big pump. Put it on the test stand and found some injectors that would handle the amount of fuel that this thing is capable of flowing.
It flow’s even more fuel than my last one and is not maxed out. We did do some things different this time and did not try and max it out on the test stand. We also did not use the spec VE pump injectors on the test stand so that might have something to do with it flowing more, but we are not totally sure. It spent probably 5 or so hours on the test stand trying different things, but for right now I am going to keep my mouth shut
on what worked and what didn’t
My spare pump was pretty much toast so I had to dig through a box of old parts and find some that would work. So I do have a spare just in case the big pump should fail, but I have reasons to believe that it will be just fine knock on wood.
I have been taking it easy on this new pump as recommended by KTA so it will be a while before any real results come about. I have another issue that I have to take care of before I can go play on the dyno. My rear-end sounds like it is going south so I need to take care of that and I am also going to wait until I get my new injectors before I go spend a day on the dyno. I would also like to get some more miles on the new pump before I turn it to max. So far I have 350 or so miles on it and its running fine. I do have to check the timing tomorrow, because it has never sounded like this before. It sounds way to high.
I will keep everyone up to date on how everything is working out.
Stomp
. My spare pump was pretty much toast so I had to dig through a box of old parts and find some that would work. So I do have a spare just in case the big pump should fail, but I have reasons to believe that it will be just fine knock on wood.
Stomp
Good to hear that it sounds very promising. To bad about the rear diff. I can't wait to see what that pump does. Lets cross our fingers and hope all the bugs are worked out. Congrat's on the new flow numbers!
I am going to do a litttle tunin on my truck at the end of this next week finally got the dyno time. So I will have some new numbers with the N2O finally.
Thanks
Brenden
Thanks
Brenden
Good luck with it Stomp! Was there ever a definitive diagnosis of what caused the first one to die?
I know that I still have a few things that I need to do like move my fuel pressure gauge to the other side of the fuel filter and run a bigger line to the pump from the fuel filter housing. Will it help???? It can’t hurt right??? Less restriction = more fuel going to the pump. Fuel=lubrication I am also doubling up on the additive. I did run a recommended dose in every tank with the last KTA pump.
On a side note I found out that the injectors that I have been running for 6-7 years (my honed 370's) have a pop off pressure of 4000psi or 280 BAR.
We took them out and checked them because my motor was missing a little. They checked out fine. The miss is still there untill you raise the RPM's and then it goes away and runs real smooth. Stomp
Stomp..
How long had you been running your FASS?? Any idea on the size of hole in the return fitting.. been thinking of a more relief valve for the outlet of the pump.. more of what the P pumps have... help to control case pressure... but it could just circulate a lot of fuel through the pump.... but I would think that the high case pressure would just damage the front seal???
Cody's pump was junk... even the case was damage...
Stomp
Originally Posted by runamuk
Are those the super secret injectors that were mentioned in passing at the RPM event??
Rick
Rick
Originally Posted by JDGnut
Stomp..
I found a Dana 80 and the plan is to go get it next Saturday. Its not that bad of a job so I will see if I can get that in before to long. Last time I talked to KTA he told me to put 1K miles on the pump before I max it out. I have 760 miles on it now so it wont be to long before I strap it down and she what she can do. I just want to make sure I have that other rearend in before I jump on it.
POD's
I did hear from one individual
that he actually made more power with some honed out POD's than he did with some different injectors that flowed the same, but had more holes. So figure that one out.
Stomp
Hey stomp, Your truck came with a Dana 80 from the factory right? I'm not sure what the dodges came with as I don't have one
any way if you want to get rid of your old 80 I am looking for one to build.
Thanks
Brenden
any way if you want to get rid of your old 80 I am looking for one to build.Thanks
Brenden
So they are the same or the same type anyway
Rick
Rick
Stomp
