Stomp?
Originally Posted by bgilbert
If you can pry the specs out of kta
, you can have just about any pump shop build you a good set
If you remember correctly I made over 600hp with them
. There is a dyno sheet in my Photo Gallery if you havent allready seen it. I just wanted to try something different. I have a couple of other options that I am going to check out
Good things come to those who wait. I have only one guy to worry about (KTA) and its still winter back there. There is also one in BC, but I havent heard any numbers from that side of the border yet. Should hear something soon though.
May Madness is where I want to lay down some big numbers
. So I have some time to get everything in order. Stomp
Originally Posted by swank
those turbos spooling a little better now, cody? sounds like you guys are having fun.
Long time, no talk. Naw, still havent messed with the wastegates on the turbos yet...just now getting the truck running again after some problems. My soultion to any problem is to add more fuel.
I did happen to find an "oddball" VE pump and is apparently a little more juiced up than the 160hp versions. Gotta find another 100 psi gauge before I can tell how much more boost I gained from it.
