stock turbo?
Old Feb 29, 2008 | 11:22 PM
darkale69's Avatar
stock turbo?
my question is would i do my self a favor in replacing my stock turbo and replacing it with a different year like a 93's turbo. I am trying to keep my fuel mileage the best i can but don't want to be driving a dog.
another question i have is what would be the largest injectors i should run on the stock turbo.
Old Feb 29, 2008 | 11:26 PM
Alwaysworking's Avatar
alwaysonDTR
why would you need to replace what you have? is it bad? or do you just want more power?
Old Feb 29, 2008 | 11:37 PM
darkale69's Avatar
i read that the stock turbo on the 92 uses a 21cm housing and other years use a smaller one, not sure right now on the size i think 18cm.
Old Feb 29, 2008 | 11:43 PM
alwaysonDTR
if you just want it to spool faster then you can change the exhaust housing out for a smaller one.
Old Mar 1, 2008 | 12:19 PM
darkale69's Avatar
i could but i want some opinions i was thinking of doing a 16cm housing but i want to conserve fuel and dont know how much i will lose by doing these changes. I want to run ddp 80+ but i dont know if the stock 21cm housing or 18cm housing will keep up with them.
here are some mods i am planning.
bhaf with old smokey mount
stans exhost
injectors (dont know size yet either ddp 40+ or 80+)
fuel pin (either grind my own or pdr if the mpg loss isnt to bad)
3200 spring
i have boost, pyro, and tach just havnt installed yet.
Old Mar 1, 2008 | 12:55 PM
turboguy121's Avatar
if i were you i would put a 14cm housing on it.Not only will it help you with quicker spool it will help with the new injectors
Old Mar 1, 2008 | 01:12 PM
C/PRD/'s Avatar
DDP4's are too much for your stock turbo for a DD without other supporting mods. I think everyting on you list is good but the injectors and just gring your own pin. A 14cm gated housing will give you a very lively truck. The injectors on the other hand, New Era 300's or 330's would be the most I would reccomend for a DD and economy! With all that and some timing you should have a sweet runner.
jaconst
Aug 16, 2014 11:00 AM
D45
Aug 11, 2008 12:26 AM
jgiachino
May 12, 2008 02:06 AM
Robert P
23
Mar 1, 2007 12:21 PM
Lark
18
Feb 12, 2007 06:34 PM
