Stock 91 CTD A/T, increase fuel mileage Mods
Hey Guys,
Newbie just bought 2wd single cab 3/4 ton.
What a truck! I have an old MBZ 300SD and
I couldn't believe the power this baby puts out
compared to a diesel Benz. Anyway to the point, I would
appreciate feedback on how to maximize the fuel
mileage with performance mods and the like without sacrificeing
reliability and try to stay within a $750.00 budget??????
I have a cabover camper (8') I intend to use and will be towing
a 17' boat. Any ideas what mileage i might expect hauling on the flat.
BTW: What about the trans, any concern here??????????
Thanks,
Bryan
Thanks,
Bryan
First off, welcome to DTR!
For base fuel mileage, you'll probably see anywhere from 19-23 highway empty, it all depends on how heavy your right foot is.
For some simple mods, I'd start out with a boost and pyro gauge. Monitoring your pyro temps is crucial when towing. If you want, throw in a tranny temp gauge in there too. Next is the BHAF (big honkin air filter). Its a much bigger than stock air filter and it flows much better than the stock setup. I'm not too sure on the auto tranny since I have the 5 speed, but from what I understand, the auto trannies on these trucks are solid. Its the garbage torque converter thats the problem. A DTT 89% torque converter is popular around here and the guys who run them like them and they say its a great improvement over stock. The converter will probably break the budget but from what I hear, its well worth the money.
Im just guessing on your towing/loaded mileage so don't yell at me if you don't get what I've predicted
, but anywhere from 12-15mpg sounds about right.
If you want more power, there is plenty in the injection pump. Now tweeking the pump will decrease the mileage (more fuel=less mileage), but its not a crazy drop, maybe 1-2 mpg.
If you need more info, ask away.
, but anywhere from 12-15mpg sounds about right.If you want more power, there is plenty in the injection pump. Now tweeking the pump will decrease the mileage (more fuel=less mileage), but its not a crazy drop, maybe 1-2 mpg.
OK...... Im in with gauges and a new TC. Budget be damned!
After reading more of the posts on this site I have decided to
make the reliabilty changes and the other mods to enhance
mileage/performance. I am planing on doing BHAF and exhaust
mods. I have the BHAF figured out, I am looking to do exhaust
mods without getting to loud. Should i go to my local muffler
shop or go with one of these on-line companies??? $$$$
(all ideas welcome)
Next looking for adjustments that i can do to the inj pump,
again not really looking to increase power so much, just
want to maximize fuel mileage. I would, if possible, like to
have a base line starting point for whatever screw adjustments
i will need to do. (again all ideas welcome)
Thanks in advance!
Bryan
(all ideas welcome)
Thanks in advance!
Bryan
Not many local exhaust shops can do custom work any bigger than 2.5". Better to buy a kit.
Pump adjustment info can be found in the tech facts section of the site, as well as in the forums. Poke around a bit and you will find a lot of info. Advancing the timing will make the most dramatic improvement to mileage. With stock fueling you will want a smaller exhaust housing for the turbo, as advancing the timing hurts spool-up some.
Moobesor
Apr 16, 2008 09:35 PM
berok
Jul 5, 2007 07:00 PM
jthorpe
31
Aug 6, 2006 01:39 PM
hopak
Sep 11, 2005 08:05 AM
