Steering wheel shake after Borgeson swap
Shaking is erratic, and shakes more as the speed increases. It is not an uncontrollable shake, just annoying and disturbing because it never shook like that before the Borgeson install; just had the "death wobble". Under 60 mph and all is smooth. This is my 2nd Borgeson swap. Curious to know if there was something I overlooked or did wrong. Rubber disk(joint) is still stock and still in great shape. Advice?
The more I stew on it, I am wondering if maybe I did not leave a gap between the splined shaft grom the PS gear box and the end of the Borg Shaft. If I remember right, in the instructions, it mentioned something about leaving a slight gap there. I thought I did, maybe not.
I just had my tires rotated, and the steering wheel shudder was happening before that, also.
I had a similar problem. The steering was just sloppy all around. After repairing the stock shaft I could tell something else was wrong. The tierod and drag link were shot, so I replaced them. After all that the tires were starting to cup on the outside and causing death wobble. New everything now and drives great.
fixed the problem
Turns out initially towards the end of the Borgeson install I took it upon myself to lock down the donut that slides up and down the shaft right up against the U-joint, instead of sliding it upwards towards the rubber weather boot that covers the adjustable section that slides in and out of each other in the Borgeson shaft. The donut is meant to lock down tight against the bottom edge of the rubber boot, as specified in the instructions
Don't really understand the reason why but it took all vibrations on the steering wheel away. All is good! Thanks, guys.
hoghunter
Feb 4, 2013 12:28 PM
ninety3CTD
Jul 15, 2007 03:07 PM
OldSmokey
Jun 12, 2006 12:11 PM
