steering box mounting plate
Old Dec 15, 2005 | 05:05 AM
timb's Avatar
Well, I just ordered my new mounting plate for the old girl {again}. this is #6. luckily they are only 23.oo buck's each.has anyone else had this much problem with theirs.
Old Dec 15, 2005 | 09:33 AM
andyr354's Avatar
knock on wood, no.
Are you getting the bolts good and tight? Are they ever loose when you go to take it appart?
Old Dec 15, 2005 | 09:35 AM
apwatson50's Avatar
Mine broke, the bolts were tight, I just welded it back together. So far, 2 years later, its still together. knock on wood.
Old Dec 15, 2005 | 01:52 PM
Alec's Avatar
Did you check to make sure the front crosmember hasn't cracked away from the frame rail? Could make things flex and pop the plate. I think someone else on here had that problem.
Old Dec 15, 2005 | 11:25 PM
rebal's Avatar
mine broke 5 years ago i just welded it up and made it stronger
Old Dec 16, 2005 | 03:49 AM
timb's Avatar
I did weld one up once. but for the price of a new one, I just went ahead and changed it out.I have also thought about making one that is not stamped out so it would be stronger. but there is a lot of angles to machine. so far the bolts have been tight and I havent noticed any problems with the frame rails. I think the problem mostly comes from all the logging roads that we travel while hunting.
Old Dec 16, 2005 | 06:43 AM
Boatnik's Avatar
I just replaced the steering gearbox Tuesday. Boy, what a job that turned into, but that is another thread. I haven't experienced what you discribed yet, but I have only owned this truck since June. What I did learn while changing the box is, the bottom bolt is a body bound bolt. I don't know for sure why but I'll bet it has something to do with location and flexing. Second the bolts holding the mount to the frame require 150 ft lbs. torque. Hope this helps.
Old Dec 17, 2005 | 01:50 AM
timb's Avatar
Thank's Boatnik. I did not know the torque specs. on the mounting bolts. but I will sure torque them down this time.
Old Dec 17, 2005 | 10:20 AM
mhuppertz's Avatar
I welded the bracket to the frame and then pulled a bead along the front cross piece. Haven't had a problem since.
james1
Jan 26, 2019 08:12 PM
I8SMK4U
Jun 13, 2013 12:13 PM
Falcon1
Apr 7, 2011 01:07 PM
MBolivar
Jan 9, 2010 11:42 PM
serious
Mar 15, 2006 04:26 PM
