Steering box bracket
Looking for a bracket. This is the second one to crack... I'm boxing in the frame and reinforcing that area...if any one has a bracket I would like to get it soon thanks drumcrazy
Fill in your signature so that we know what advice to give you.
Can you install the bottom stabilizer that many are using? I am using the BD support.
Steering Box Stabilizers and Braces - STEERING BOX STABILIZER - BD ('03-'08, 4WD)
Bracket mone is a 93
Ll
mine is a 93...need a bracket...thanks for the reply
Unless he has something new, steering brackets themselves, are not an item he offers.
Frame boxing plate steel [inside the frame rail] options for behind the steering box bracket, sure he has that.
You would still need a good steering box bracket though.
Jungle makes a lot of great stuff for 1st gens.
I bought the kit but have not installed it.
edit: i like the idea of bracing across to the other frame rail. never looked into doing it. i just made a plate from 3/8" steel to go on the backside of the frame rail. basically acts as a huge washer. it's been on there for 2 years and seems to have helped.
yep, his kit allows you to mount straight to the frame. eliminates that crack-prone bracket.
Great idea, though. Any detailed photos of how you went about that ?
this is the only other picture i took. i just made a cardboard template first to make sure it fit inside the frame rail and then cut it from 3/8" plate. could only get the front 2 holes of the plate as there is a hump in the frame between the middle and the rear most hole. figured it was better than factory.
Hard to beat the dodge connection (or JY) steering brace that connects to the crossmember.
Power Steering Brace
