starting problems
Old Jul 21, 2008 | 05:56 PM
RAMMAN4's Avatar
starting problems
I went out and tried to start my 92 D250 today and the engine cranked a couple of times and then started clicking. So I figured that the battery was pretty dead and pulled my ford up to jump start it. Even with cables attached it did the same thing. So I pulled the battery terminals off, cleaned them and reattached everything, still the same. So I disconnected the terminals and hooked my jumper cables straight to the terminals, bypassing the battery and same thing. The map light, courtesy light, and power window work find with the jumper cables attached. I'm getting 13.4 volts through the jumper cables so I know I'm getting enough voltage. I'm thinking maybe starter? Any ideas. I was planning on using it this coming weekend to go get the rest of my parts but that might have to wait now.
Old Jul 21, 2008 | 06:24 PM
BC847's Avatar
1st Generation Admin
It sounds as though your starter is due a rebuild. Check the How-To in the Sticky.
Pure Diesel Power now sells starter rebuild parts (contacts as such).
Old Jul 21, 2008 | 08:09 PM
BearKiller's Avatar
Is it the five-speed ??
If so, just roll-start it and don't shut it off until you are done.
Old Jul 21, 2008 | 08:12 PM
bgilbert's Avatar
Hit the starter a few times with a hammer, then try starting it.
Old Jul 21, 2008 | 10:01 PM
RAMMAN4's Avatar
It's kinda hard to push start it when you are by yourself. I'll try banging on the starter some tomorrow. I was afraid it would be the starter.
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
doodah
17
Dec 17, 2002 12:55 PM
