Speedometer adapter......need ratio?
Old Dec 10, 2007 | 02:10 PM
D1EZEL's Avatar
92 4x4 Getrag with 4.10.
I have the little adapter that reverses the direction but need to know the ratio or how to find it.
Thanks
Old Dec 10, 2007 | 02:23 PM
JD730's Avatar
You don't need anything to reverse anything, 93's have a VSS Vehicle Speed Sensor and they don't care about which way they rotate. Only how fast they rotate.
This outfit has speed reducers or increasers, but I don't know which one you would need.
http://www.transmissionsone.com/
Old Dec 10, 2007 | 04:21 PM
Chrisreyn's Avatar
CAll teh dealer with the VIN and they should be able to tell you, but when I replaced mydrive pinion gear, VSS and gear reducer, teh only thing that had a ratio requirement was the drive pinion gear.. I dont beleive that it matters on teh gear reducer.
Old Dec 10, 2007 | 07:44 PM
D1EZEL's Avatar
I guess I should explain. Just installed a new Gear Vendors and need to make a slight adjustment on the speedo. So I figured I would replace the adapter with another one using the correct ratio. I know how far I am off currently but I am not sure what the little box ratio is. Once I know that I can order the correct one and replace it.
Thanks for the answers.
Old Dec 10, 2007 | 10:28 PM
Chrisreyn's Avatar
in that case I beleive it will be the pinion drive gear that needs replaced....
The dealer here has a 'cheat sheet" that, with the tranny type, and rear end ratio, woudl give the correct gear size....
zack_76401
Apr 14, 2011 09:13 PM
MBolivar
Dec 11, 2010 01:03 PM
ppiggppenn
Jun 5, 2009 10:38 AM
oilcan64
Mar 31, 2009 06:03 PM
BearKiller
Feb 17, 2006 10:11 AM
