Speedo Problems
Speedo Problems
I put a new GRR on to go along with the new VSS, but my speedo still is way off. When I'm going 55mph it says I'm going 30. I have read the sticky on how the speedo works, but I am wondering if anyone else has had this problem, or what exactly the solution is to fix it?
Thanks!
Thanks!
If its consistant with how far off it is across the spectrum, I suspect that either the wrong pinon drive gear has been installed, or that the GRR is off..
Just for giggles, remove the GRR altogether and see how it does.. and inspect the pinion drive shaft while your at it.. altho I doubt that is the issue..
then inspect the pinion gear, most of these trucks used the "yellow" gear, or the "blue Gear", but for the life of me I cant remember which went with which gear ratio..
Also inspect the wiring harness from the VSS, make sure its not chafed or open.
The pinion drive gear has not changed from the original, could it be broken? and the GRR is brand new, I ran without the GRR for a day or so and it was consistently around 15mph under what I was going.
I am suspecting that the "new GRR" is off.
is this "new" or your original that has been rebuilt?
You may want to talk to these guys and get some input from them..
http://www.transmissioncenter.net/sp...tm#90%20Degree
Do you have the original GRR that was on the truck?
