Lower door hinges!
Dodge still carries them. Also the passenger and drivers side use the same lower hinge (flipped over) and the passenger side isn't that uncommon to find in good shape in a junkyard.
What is the Dodge part number...If I want to get one from a $tealer...
Unless they're "BENT" don't waste your money.
I bought the new ones, and then I realized that the $8.00 pin kit I had to repair the old one, made it just as "new". So, now I have a rebuilt original one, and a new one that's installed on my truck....
I'm good to go, and I spent $$$ learning something new.
I have knocked out the old pins and put in new ones....the problem is the passenger lower hinge....the holes are wallowed out. The bushings pop right back out.
Thanks, Guys
PM sent to simplysmn
Thanks, Guys
This pin kit:
1. Did you purchase it from a dealer and does it include bushings?
2. Can the kit be installed without removing the hinge from the truck or the door?
Thanks,
Some folks have changed the pin out, while the door hinge is still in the truck. Faith (Wannadiesel) did a paragraph or two about it, as I remember reading many moons ago.
Personally, I took mine out, as it's a heck of a lot easier using a floor jack, supporting the door, pulling the hinge, and working on a bench, like a human... (less scraped monkey knuckles, if you know what I mean.
Make sure you take a marker and mark out the original location on the door pillar and the door side so you can get it back in the same general spot where it was. I had to "adjust" my doors anyway, and this just added a few minutes to that task. Having it out allows you to clean it properly, put the pin kit and bushings in, and sing a few show tunes while doing it....
...I did the same stupid thing on my 2nd gen...
I got mine from Rockauto, but any parts store usually has them in stock.
TIA.
You don't have to remove the kick panel.... just loosen it up, move it over a bit, and get your wrench in there.... Upper hinge on my truck(s) never needed any help, as the lowers went bad first. I assume if you let the lower one stay bad for a while, you'd have to replace the upper, but it's a real pita as the bolts are behind the dash....
