speed
Old Aug 3, 2006 | 01:44 AM
charliex25's Avatar
speed
I have a 91 and it wont go faster than 75mph down hill with a tail wind. Has anybody got any ideas how to correct this problem?
charliex25
Old Aug 3, 2006 | 02:26 AM
bgilbert's Avatar
Overdrive transmission.
Old Aug 3, 2006 | 07:34 AM
Boatnik's Avatar
Are you getting full throttle? If so you might want to put in a 3200 rpm governor spring. What rearend are you running? Is it automatic or manual?
Please fill out your signature profile so we know what we are dealing with. It is hard to give meaningful advice without a good starting reference.
Old Aug 3, 2006 | 07:46 AM
flashgordon's Avatar
Originally Posted by Boatnik
Are you getting full throttle? IF so you might want to put in a 3200 rpm governor spring.
i'll 2nt that Boatnik and bgilbert!
the over drive unit that i installed,calmed the motor down,rased the hiway speed,A LOT, and gained 4-5 MPG(I have 4:10 gears)the only real drow back is the price
toke me a fue years to deside it was worth the price!
Would do it all over again if i had the cash!
Old Aug 3, 2006 | 08:34 AM
charliex25's Avatar
Yes 5speed auto. Thank you ,filled out the signature card.
Old Aug 3, 2006 | 08:52 AM
G1625S's Avatar
have somebody cycle the accelerator pedal (no 'gas' pedals on this site) while you watch the linkage on the pump. There is a high idle stop screw that the linkage should be hitting when the pedal is to the floor. Adjust any slop in the linkage that may be preventing full throttle, and back that high idle screw out some if you can. The next step will be a higher RPM governor spring. Do you have 4.10's?
Old Aug 3, 2006 | 06:35 PM
mhuppertz's Avatar
If you have a TorqueFlite 3 speed you are doing good to make 75. A 3,200 governor spring will give you about 15mph more in an auto.
Old Aug 3, 2006 | 07:31 PM
G1625S's Avatar
hey Charliex25, I still can't see your signature. Check in the usercp to see if it remembered what you filled in. You're a 5speed, right?
Old Aug 3, 2006 | 08:07 PM
Begle1's Avatar
A 1991 auto has a 3.07 rear end, correct? My truck, with a stock tranny, TC, differential and governor spring, can hit 75 up a 8% grade and at 15 PSI boost, can go 80 on flat land with 5-8 PSI boost and can get over 90 going downhill before it starts feeling like an airplane.
At the stock governed RPM of 2500 RPM with a 3.07 rear-end and stock tires you should be at 75 anywhere, and around 80-85 freewheeling the engine on flat land. So you have a problem; most likely insufficient throttle pull.
Old Aug 4, 2006 | 07:11 AM
charliex25's Avatar
I resaved my signature
faster_than_ford
33
Mar 5, 2004 07:24 PM
Sonny
Feb 15, 2004 11:47 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
