sorry turbo ? from a noob
hi all ive got a 92 w250. i bought from a friend he wrecked it. i gave him 500 bucks for it.any ways i understand my truck has a H1C with a 21.ive been told to get a HX35 and a 16. how much power will these support? can i step to a HX40? ive got my 32k spring and will turn up the pump up and do injectors.and yes the trans is in the works.is this a good start to 400hp? please teach me im new
Yeah its a good step. Im running POD injectors, HX35 with a 14. Ive been told Im around 300, and as Im going intercooled, I should be able to milk some more out of the pump. If you can find an hx35 for cheap do it, otherwise get a Gillette upgrade for your h1c and a housing. HX40s do alright but are a little harder to spool and not near as reliable (weak shafts). A good similar but much better alternative is the s300 or htb2 series.
I would buy a 16cm housing for you h1c (same housing as one you would by for HX35) then a stage 3 or 4 compressor upgrade for it....................Hmmmm.....400 HP
don't waste you time on up grading your turbo or a HX35......the HX40 is bigger but has a problem with main shafts breaking and is why you see talk of the fat shaft 40'smy knowledge really starts to get foggy after a HX35......
If your short term goal is 400 just state throwing fuel at it until you egts start getting to toasty then open you wallet wide, buy a bigger turbo
If 400 is a long term goal.......like a couple of years, then up grade you h1c for now and then sell it to help on the bigger price turbo later on.
Flash
The problem with the 40's is it's a big turbo on the exact same shaft as the 35. They are both weak and if you want to make power, not problems then the Phat Shaft from Industrial is awesome. The Holsets will get you there no problem but the will fail when pushed. Too much drive pressure and boom.
well so it looks like im gonna have to save up 120,000 of my pennies.what is the better of the tow houseings? a 16 or a 14 with a w/g my truck has an auto. thanks in advance for all your info. im new and im learning as fast as i can
You would be surprised what an h1c upgrade or hx35 will do to your seat of the pants performance. (Not to mention get you well beyond 300horses) I would recommend starting slowly with a turbo upgrade, making sure you want to get crazy before dropping the 4 digits on a turbo.
what can i do to my h1c as far as upgrades.is there a site somewhere? so you dont have to waste your time on me.this is my first diesel and i want to learn i dont want to be one of those guys that take the truck to someone and say this is what i want
For $350 a good used HX35 would be a better investment. Plus you're gonna get a smaller wastgated exhaust housing. I have spent the money on a stage IV and it's still cheaper to HX35 it. Later if it's not enough then upgrade to an s300 or equivilent. Just my .02! It's all gonna be expensive no matter what you do. LOL
dslpwr81
Aug 9, 2008 12:25 AM
4x4dually
25
Sep 20, 2006 01:53 AM
Loppy
Sep 25, 2003 04:42 PM
