Snow performance stage 2 "universal" kit
Old Jan 17, 2012 | 07:36 PM
1992gen1_fan's Avatar
Hello, I ordered a snow stage 2 universal water/methanol injection kit. It says something like works on any make with a larger turbocharger. Being a universal kit will it work on a diesel? I should have investigated it more before I ordered it. Anyways, any of you run this kit successfully on a cummins? thanks
Old Jan 17, 2012 | 09:06 PM
I guess basically what I'm asking is do the universal kits work on our trucks? Or do I need to get the diesel specific kit?
The kit says:
-180psi pump
-for turbocharged engines
Old Jan 20, 2012 | 09:49 PM
Ok, the kit came in. I cant wait to get it installed. Where does everyone mount everything (tank, pump, nozzle)???
Old Jan 20, 2012 | 10:23 PM
93-12Smoke's Avatar
I would do the tank in the bed and the pump under the bed with nozzles in the intake elbow. Pump needs to be lower than the tank I would bet.
Old Jan 21, 2012 | 05:38 PM
The instructions say that the nozzle needs to be the highest point in the system. Did'nt say anything about the tank being higher than the pump. Makes sence though.
Ok, I have a dump bed.. I was almost thinking to install the tank and pump up front kind of in front of where the air filter is. What do you think??
Intake elbow? The one on the intake plate or near the turbo? Thanks
Old Jan 21, 2012 | 06:08 PM
93-12Smoke's Avatar
The elbow above the grid heaters.
Old Jan 21, 2012 | 09:16 PM
Flake's Avatar
How much boost is this kit designed to use?
Most gas turbo/supercharged kits make much less boost than even a stock Cummins, the computer for the water/meth may not be able to use the psi numbers if it's made for a gas vehicle.
Old Jan 21, 2012 | 09:39 PM
Ok, thanks.
Old Jan 21, 2012 | 09:43 PM
Thats what I was wondering about. Im not sure what its supposed to use. I have the kit now so I'll probably try it out and if it don't work I guess I'll sell this controller and buy a diesel specific one.
Old Jan 25, 2012 | 12:13 AM
Hello, I got the kit hooked up. It seems like it really makes a difference going up hills. It seemed to really make a difference in egt's too. This was using a -20*f windshield de-icer. I think this controller is going to work ok since my truck is really mild and lower on boost than alot of others' trucks.
I think I'll really like this mod
Alaska Sunrise
Feb 7, 2009 06:54 AM
Mega Bass
15
Apr 20, 2007 08:13 PM
masonic-dodge
Mar 22, 2006 04:56 PM
Hoss
Dec 10, 2005 02:30 AM
