Slow down there, Pump the brakes
Old Sep 2, 2010 | 02:49 PM
Scotts_D250's Avatar
Its been a while since i kept you guys up to day.. but i was soo busy i didnt have time to fix the truck.. today i woke up early and fixed the problem.. i just replaced the master cyl and bled the brakes... now i stop on a dime. thanks everyone
Old Sep 3, 2010 | 09:32 PM
MBolivar's Avatar
Glad to hear all is good! Now upgrade your rears to the 3" 1 ton shoes and cylinders and you'll be stopping on a .... nickel? Couldn't think of anything smaller than a dime.
Old Sep 4, 2010 | 04:00 AM
dzl_damon's Avatar
I had the same problem and replaced the master... only helped partially. Got the rear hubs and drums off to find the self adjuster wire with the springs were missing! So the adjusters could hold the lever onto the star wheel. Stops great now after replacing them too.
Old Oct 7, 2010 | 03:15 PM
KKRRSS's Avatar
If you're not losing fluid, and pumping it brings back the braking power; it's the master.
Old Oct 7, 2010 | 05:48 PM
Douglas2's Avatar
Must disagree on that one. Bigger shoes and cylinders are not going to get you stopped any faster unless you've got lots of weight in the bed; all more brakes there will do is lock the rears more quickly which won't get you stopped faster( unless you wind up hitting something solid ).
cheers,
Douglas
Old Oct 7, 2010 | 09:03 PM
KD93's Avatar
cheers,
Douglas
Don't we have a load proportioning valve? I don't know if we do or not, but if so that's going to help right? And if the ABS is working, won't that help with lockup too? I think I know where you're going, and it would be better to have bigger brakes at the front unless you're loaded, but aren't there ways of overcoming lockup through onboard hardware?
Old Oct 8, 2010 | 07:46 PM
No, we don't have a load sensing valve. Full braking power is always available. The 1st gens rely on the RWAL to keep the truck from swapping ends when empty.
edwinsmith
Mar 25, 2006 10:00 PM
Buffman88
Jan 22, 2006 08:25 AM
wildcargo
Nov 29, 2005 04:20 AM
Davidp
15
Mar 31, 2003 01:10 PM
