Sick Running Truck
Old Apr 23, 2008 | 09:47 PM
wheelo90's Avatar
Sick Running Truck
Upon playing with my AFC (spring removal for a smoke show), I accidently lost one of the copper looking washers that hold the AFC line.
Here is where it gets a bit confusing, With the spring removed, and my AFC to the deepest position, I have zero smoke at all. I can hit 3,000 RPM like nothing, revs fine, doesn't miss, starts as normal. But has zero power. Before I pulled the shaft to put it to the deepest positon, and to remove the spring, my diaphram was loose, so now I can only get it close to stock position.
But I mainly want my power back.
Before, I could pull hills at 60, now I pull them at 45 if I'm lucky.
Help Me please Someone!
Wheelo
Old Apr 23, 2008 | 09:55 PM
bgilbert's Avatar
Replace the missing copper washers. Pump see little to no air, produces little to no fuel.
Old Apr 23, 2008 | 09:57 PM
Alwaysworking's Avatar
alwaysonDTR
is the fuel pin stuck?
is the spring in there now? or is it still out?
Old Apr 23, 2008 | 10:01 PM
wheelo90's Avatar
How could the fuel pin be stuck, how does one check to see without causing any damage?
Spring is still out.
If the pin is stuck how do I free it up?
Sounds to me like it might be, it is the only thing that would make sense to me.
Thanks very much!
Wheelo
Old Apr 23, 2008 | 10:06 PM
alwaysonDTR
you check it buy moving the throttle with the afc out if the little pin pops out it should be fine re-read the sticky on pump mods
i used wd40 on mine
another thing did you remove the plastic washer when you pulled it back apart, if you did then the afc is probally holding the pin in because its down too far
Old Apr 23, 2008 | 10:17 PM
wheelo90's Avatar
Alwaysworking,
Your the MAN!
I will check them tomorrow, I do know that the plastic washer is not where it belongs.
Thanks!
And keep the help CUMMINS
Wheelo
Old Apr 23, 2008 | 10:20 PM
alwaysonDTR
its in the pile with the rest of the parts, right?
Old Apr 23, 2008 | 10:27 PM
bgilbert's Avatar
Did you find the copper washers? If so, then I would reinstall the plastic washer on the fuel cone. Without it allows the cone to be too far down and not allow the pin to come out (with afc spring mia).
Old Apr 24, 2008 | 09:15 PM
wheelo90's Avatar
WOW SUN OF A GUN!
I pulled the shaft out and looked to see that my fuel pin was not moving at all. sprayed some carb and choke cleaner down in her, and put the plastic washer back on the shaft. Took it for a spin and, smoke city. she blows some smoke alright. Major thanks goes out to Alwaysworking and bgilbert!
Thanks!
Wheelo
Old Apr 24, 2008 | 09:32 PM
alwaysonDTR
i hope you have a pyro.
where are the vids of it?
Old Apr 24, 2008 | 09:40 PM
wheelo90's Avatar
pyro next!
Not very computer inclined for a 17 yr old kid! but will be workin on some pics
Thanks!
Wheelo
Kennys
Oct 21, 2010 08:18 AM
bigman
13
Aug 24, 2009 10:05 PM
codered
0
May 21, 2007 11:20 PM
53 willys
16
Apr 30, 2007 09:30 AM
Big Jim
Oct 24, 2006 01:06 PM
