Shifting problems
Old Aug 29, 2010 | 07:40 PM
burdisp's Avatar
Shifting problems
Im having a hard time getting my truck into some gears, i took it in and now i cant get it into 1st gear, i cant find new or even used parts. Dose anybody know how i can fix this or possibly a place to find some parts. I have an 89 1st gen cummins.
Old Aug 29, 2010 | 07:57 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
youll probably have to say if you have an automatic or 5 speed.
Old Aug 29, 2010 | 08:44 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
I bet its a CVT. ;-)
Welcome to DTR. Look in the " user cp" to fill out your signature so we know what you've got. A lot of smart folks here willing to help
Old Aug 30, 2010 | 10:25 AM
burdisp's Avatar
sorry i have a automatic
Old Aug 30, 2010 | 12:28 PM
Well if the automatic aint going into gear, then that's a bad thing.
Sounds like it's a rebuild time for your tranny. I'm not sure but did the early 89/90's still run the 727 with a lock up converter? Or did they have the 518od unit already?
Regardless both tranny's are rebuildable, lots of parts out there, so don't worry about that.
Old Aug 30, 2010 | 01:24 PM
DodgeMonkey's Avatar
The 89-90's had a TF-727 with a NON-lockup converter, so did the A-518s. I would check your linkages and make sure that there isn't any binding, and that the bushings are all good. Before that though, I would disconnect the linkage at the transmission, and make sure that the problem is not internal, by manually moving the shift arm with your hand from under the truck.
Old Aug 30, 2010 | 01:25 PM
Onemoparnut's Avatar
89-91 had a non lockup 727 91.5-93 had the 518 non lockup also.
Old Aug 30, 2010 | 03:06 PM
burdisp's Avatar
Thanks
Old Aug 30, 2010 | 04:40 PM
If the tranny shop you went to tells you that parts for a 727 are not available I would find a new tranny shop. The only part that might be a little hard to come by is the case cause it is diesel only. But I your case should be reusable. But other than that parts are readily available for that.
kellio
19
Mar 26, 2021 03:12 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
CountryDiesel
Dec 1, 2003 10:24 AM
