Self adjusting breaks?
Old Dec 27, 2005 | 02:02 PM
Blowndodge's Avatar
Self adjusting brakes?
Hey, I thoughts these were suppose to be self adjusting brakes on our trucks? I just did the rear drums about six months ago, all new parts including hubs (don't ask ) neglect will make you do stupid things! Anyway, I noticed the other day that I sure have been standing on the break peddle hard lately and I think I smell the front disc over heating.
I decided to drive in reverse and hit the brakes a few times but no avail. I finally jacked up the back end and manually adjusted the driver side first and I must have spun that dial 5 times around before I heard the shoes scraping the hub. The passenger side on one full revolution (5 full strokes on the starwheel) and it started touching too. The difference was amazing. I had to learn to brake all over again.
Is this the way it is with self adjusting brakes? Man do they suck.
brad
Old Dec 27, 2005 | 02:07 PM
spunbearing's Avatar
Sometimes they work sometimes they don't. It's a good idea to change the self adjusters when you're in there. The older they get the less they work like they're supposed to. I cleaned mine up and put some lub on the threads and they work pretty good. ( knocks on wood)
Old Dec 27, 2005 | 02:20 PM
Geico266's Avatar
I think most of us just hand adjust them every oil change. A few clicks and you are good to go for another 3 months. Your E b rake shgould ahve told you there was a problem also. It should start braking within an inch or two of the top of the peddle travel.
If you really want good braking replace the stock slave cylinders with 1 ton GM's. Just hold on to your coffee.
Old Dec 27, 2005 | 11:54 PM
DesertRat93's Avatar
Better yet, get rid of those lousy drums and convert to rear disk. You'll never need to adjust them again.
Old Dec 28, 2005 | 10:57 AM
Nuttymopar's Avatar
Every time I was inside my rear brakes, I noticed that the self adjusters were OFF of their position. I ended up finally just cutting that cable as it never did work for mine.
Old Dec 28, 2005 | 11:59 AM
Boatnik's Avatar
What year truck would i get disc brakes from that will go under a w350?
Old Dec 28, 2005 | 12:04 PM
John Faughn's Avatar
One thing is if the shoes weren't close enough to touch the drums when you 1st put them in then they would not adjust , the next is the self adjusters work while backing up and taping the peddle , then a nother is its easy to put the adjuster on backwards.
Old Dec 28, 2005 | 04:45 PM
I put in all new hardware when I was in my rear brakes this summer and the self-adjusters seem to be working - for now.
To expand on what John said: the FSM says that the self adjusters will work IF you hit the brakes in reverse, come to a complete stop, then drive forward a couple feet.
Old Dec 29, 2005 | 09:52 AM
jleonard's Avatar
HTML Code:
These are called "self adjusting" because if you want them adjusted, you have to crawl under the truck and adjust them yourself.
Old Dec 29, 2005 | 10:34 AM
PeytonMaterne's Avatar
I had a problem with my right rear wheel over tightening itself after a short drive, to the point that I couldn't push it(the truck) back and forth in the garage. I removed the cable portion and haven't had that problem since, just have to adjust it myself.
Old Dec 29, 2005 | 11:17 AM
Dan Brooks's Avatar
Sounds like the adjusters got swapped side-to-side....
No matter how hard I try, I can't get mine to "self-adjust" - but it does get lots of strange looks when I drive 40 MPH in reverse and slam on the brakes. I normally adjust mine when I change the oil or before I do any heavy towing.
jrs_dodge_diesel
May 13, 2015 10:56 AM
Polarlys
May 29, 2009 08:26 AM
Euronymous
Oct 15, 2007 06:21 AM
PsRumors
20
Mar 9, 2006 09:59 PM
Mostwanted
Sep 17, 2003 09:36 AM
