?s on hx35
?s on hx35
k i got my hx35 off my parts motor. now its says its a
hx35w whats the W mean. on the intake side its 12 stamped in so i guess it 12cm houseing. if u were to change the houseing to an 18 or 21cm houseing what am i going to see one i know is lag but will there be different in boost levels from each houseing. how much can the turbo shaft hav in play up, down and in, out play should it hav little to none ? the exhaust manifold looks high flow to like one u would buy BD would it be good to take the manifold and bolt it the hx35 back to it and put it all on my truck would it all work good ?
the motor is a 24valve that i took the turbo from
Dawson
You haven't stated if your truck is an auto or stick. The 12cm housing seems to be a favorite of the stick shift crowd. A 16cm or 18cm is the prefered one for the auto people.
Like EMS said. Figure 5 to 10 PSI if your going from the stock 18cm to a 12cm.
ya wheels r all good no touch on walls
but another ? what kind of egt number should i see with out turnning pump will it to hot right of the bat should i put gauge in when i put turbo on to
