Rust on injector?
Old Sep 7, 2013 | 10:35 PM
dieselluvr's Avatar
Rust on injector?
One of my injectors I pulled (#6) had rust on the outside. Does this mean I have an antifreeze leak?
Old Sep 8, 2013 | 08:00 PM
swirv7's Avatar
Is the #6 injector the second one from the bottom? It's a little hard to see in the pic.
Old Sep 8, 2013 | 10:08 PM
dieselluvr's Avatar
Injectors are 1-6 from top to bottom so #6 is the bottom one. doesn't look red anymore because my greasy fingers fixed that but when I first pulled it it was red with rust everywhere you see the surface is roughened.
Old Sep 9, 2013 | 07:07 AM
swirv7's Avatar
I would check your oil or coolant. From what I see I wouldn't worry about it. Those hold down nuts tend to let moisture in.
Old Sep 9, 2013 | 08:20 AM
j_martin's Avatar
Most used injectors have some rust pitting on the barrel. Atmosphere, road salt, etc. gets past the hold down nut pretty easily. Not a problem unless severe, as in leaking through the rust.
Rust on the tip, however, could be trouble.
It's hard to answer your question when you wipe the evidence off then post pictures.
Old Sep 9, 2013 | 10:00 AM
bannerd's Avatar
If it was coolant (especially in the injector area) you would be smoking all over the place even at idle
madhat
Nov 16, 2014 03:56 PM
The Boss Hog
40
Mar 4, 2003 10:33 AM
Holsteinman
Feb 5, 2003 09:26 PM
Evildiesel
Jan 7, 2003 02:46 PM
Stamey
22
Jan 2, 2003 09:27 AM
