Rotary Mech IP ?
Old Jun 22, 2006 | 10:51 AM
qwest's Avatar
Rotary Mech IP ?
As I understand , the older Diesels had a rotory pump /
Any comments on reliability of this pump.
Old Jun 22, 2006 | 11:03 AM
Begle1's Avatar
It's about as reliable as a standard gasoline engine. They're known to run 300,000 miles or so, if not more.
Since it is a fuel lubricated pump it isn't quite as good as the P-pumps, but it is a great pump nonetheless.
Old Jun 22, 2006 | 06:20 PM
The VE is quite reliable. It's not a bulletproof pump like the inline pumps on 2nd gens, but most make at least 250k, with some passing 400k.
Old Jun 23, 2006 | 07:37 AM
qwest's Avatar
How hard would it be to put one on a 02 24V ( replave VP44)
Old Jun 23, 2006 | 11:48 AM
PapeCAT's Avatar
you want to replace the vp44 with the VE44 is what are saying. I have thought about this as well. the VE44 is a fully mechanical pump. Not sure what you would need to get it to work.
Old Jun 23, 2006 | 04:18 PM
qwest's Avatar
That's what I was exploring, seems the in line pump is a harder
conversion.
Old Jun 23, 2006 | 04:29 PM
To swap a VE in would be even harder because the timing case is different. If you want to swap pumps on a 24 valve, the inline is the way to go.
screaminbanana
Jul 15, 2005 12:22 PM
Mechanos
Jul 24, 2004 05:11 PM
Den052
Oct 9, 2003 10:35 AM
Den052
Jun 21, 2003 12:45 PM
