ring & pinion
Old Feb 27, 2005 | 12:19 PM
timeagain's Avatar
Question ring & pinion
Does any body know wear to get new gears for my Dana 70 in 3.07 ratio?
I have a 89 auto,4+4 w250, as far as I can tell nobody sells them any more.
Old Feb 27, 2005 | 12:45 PM
Redleg's Avatar
https://www.dieseltruckresource.com/...threadid=62005
You have to find a used replacement. The few I saw on some salvage web sights were only a hair cheaper than a new one and were in the 100, 000 mile range. See if you can find a junker locally and swap axles, you can then over haul the seals if needed. I saw a set on E-bay once, but you need the carrier too if yours isn't useable.
Old Mar 2, 2005 | 10:35 PM
DeanM's Avatar
http://www.ringpinion.com/
Try here for the R&P
Dean
Old Mar 2, 2005 | 10:43 PM
Den's Avatar
Den
Somebody needs to hint to Richmond gear or somebody that a run of these would be a good idea
Den
Old Mar 3, 2005 | 07:55 AM
92DIESEL's Avatar
I found one in a Colorado junk yard, only $1250 delivered and 30 warranty.
To rich for my blood.
Timeagain PM me if you want the info I got
Old Mar 3, 2005 | 10:18 AM
FNJ's Avatar
FNJ
I bought my 1990 W250 for 600.00 dollars because it had blown 3.07 rear . I looked around for awhile but couldent find one for under 1500.00 dollars! I could not belive my luck when I found one at a local junk yard I was there looking for parts for my diesel volkswagon when Isaw a Dodge truck with no motor upon further inspection I saw a large exhuast pipe! Ran the VIN # BINGO 3.07 rear!! I asked the guy in thye yard how much 150.00 dollars. I got fabric burn from pulling the money out of my pocket so fast!!!! SO when you go to the wreckers check thoes 2wd Dodges. John
Old Mar 3, 2005 | 11:43 AM
Redleg's Avatar
Dean
Dana quit offering it to everybody in '97. Might get lucky and find a set in storage in a barn somewhere, next to the cherry, 25,000 mile, Hemi Daytona the farmer is hanging on too as the mice make it a home.
Old Mar 4, 2005 | 08:07 AM
timeagain's Avatar
Well thanks for the replies, no luck in finding one yet. I just might have get another truck.
If I do I'll have some parts to sell!!
Old Mar 5, 2005 | 08:37 PM
timeagain's Avatar
Well here we go, I just got another truck!! A 98, 2500, 12 valve, long bed 4 door, ats 4seed.with split ratio 3 locker, 4" ss ex, pac brake, rancho air ajustabl, air bags, class 5, mt wheels,270 hp plates,ajustable gas plate,ats exaust header, for 16000.00 With 12500 miles
Old Mar 5, 2005 | 08:44 PM
You practically stole that truck! Good find.
HaulinBut
May 12, 2006 03:06 PM
LanceD
15
Jan 7, 2005 06:54 PM
Steve-l
Nov 16, 2004 02:33 PM
rednose
23
Jan 25, 2004 12:21 AM
pwabbott
54
Dec 5, 2002 08:26 PM
