replacing head gasket
Old Oct 11, 2017 | 10:04 PM
  #46
Boatnik's Avatar
Originally Posted by bigragu
What refrigerant did you fill into your A/C system? Back to R12?
R12 is out of reach expensive. I converted to 134a several years ago and will probably continue with it. I mounted the new condenser but I couldn't fill the system because they didn't include a new gasket with it. And of course my supplier didn't have one in stock. I will do all that friday.
Old Oct 11, 2017 | 10:12 PM
  #47
Boatnik's Avatar
Wide open throttle I got 38 pounds boost without drugs, respectable smoke initially fading to a strong haze and 1600 degrees pre turbo in about five seconds or so. I need more air. guess my next project will be aimed at the turbo and intercooler. I believe I got all I can from that H1C.
I have been talking about it ever since I installed those stage 3 injectors. Time to get serious.
Old Oct 11, 2017 | 10:28 PM
  #48
edwinsmith's Avatar
38# with an H1C is great. I upgraded to a WH1C and I used a boost cheater to set it at 36#. I could only get about 20# out of my H1C.
Old Oct 13, 2017 | 08:11 AM
  #49
Boatnik's Avatar
The H1C has the HTT Stage 4 compressor and housing. With the proper mix of meth and water I can get 43 pounds but it doesn't cool the egt's very much. It just takes longer to hit 1600 degrees.
Old Oct 13, 2017 | 11:17 AM
  #50
bigragu's Avatar
Are you running the Snow's kit? What size nozzles are you running, and how many? Just curious, Boatnick, what are your thoughts on running plain water, or windshield wash fluid?
Another question, lol, as I don't see much folks on here with water injection- what boost pressures are you having your spray come on initially, then at what pounds boost do you have it set for full spray?
I have the Snows original kit from 2006, and have one 325 and one 625 size nozzles. I have my progressive controller to initially come on at around 15 psi boost and full spray at around 22-25 psi boost.
Have never run true 50/50 water methanol. Only WW fluid, or straight water.
Old Nov 4, 2017 | 01:43 PM
  #51
Boatnik's Avatar
It is a used Snow Kit I got off of Ebay years ago. It is really for a gasser. I am only running one nozzle at this time and I even drilled it out to where it is dumping almost one liter a minute. I wouldn't recommend doing that. I have run Washing Fluid with methanol, just distilled water and combinations of methanol and all the above. I noticed no deposits in the intake or under the cylinder head when I had it off. in fact i9t all looked pretty clean considering what injectors I am running. I have often wondered why we can't run denatured alcohol in the tank instead of methanol. The availability is a lot better and it has methanol in it.
Old Nov 4, 2017 | 01:54 PM
  #52
Boatnik's Avatar
Latest update: The head gasket work turned out just fine. The valves are quiet and engine is running smooth as silk. However, the little things are biting me in the hips.
The timing pin went for a trip without the truck and dumped a mess of oil in the engine room. Of course I never use it anyway but it does stem the tide when the engine is running. I found a 3/4 inch freeze plug and it has held on with some serious thrashing so far.
Next, one of the transmission cooling lines got a hole rubbed in the bottom over the cross member under the engine. A neoprime hose and a hose clamp have made a temporary fix. Had to replace a couple hangers to keep that from happening again. Planning on adding an aftermarket cooler anyway so that will be repaired at that time.
And finally I lost power to my a/C compressor clutch.
All will be fixed in due time but it sure put a dent in the celebration.
Old Nov 4, 2017 | 02:03 PM
  #53
Boatnik's Avatar
When I was running the turbo as it is today on the stock exhaust manifold I got a 8 pound boost running 50/50 H2O/meth to about 43 pounds. After installing the after market manifold it goes to 38 pounds without H2O/meth and 43 with. Increasing the methanol a little raised the boost to 45 but it started to ping and that was when i lost my original head gasket. As I said before, I think I have gotten all that H1C has to offer by it self.
andy9874
Mar 1, 2009 05:06 PM
Diesel-nut
19
Mar 7, 2008 11:32 PM
boostedte37
16
Mar 1, 2008 06:34 PM
mopar2ya
Jun 3, 2007 03:47 PM
dodgec68
Feb 8, 2007 02:47 PM
