Relay Question
Pins 85/86 are the pull in coil. One side should have power. The other side is a ground. In this case the ground is controlled by the PCM.
30 is power in for the circuit the relay controlls
87 should be hot if the coil has pulled in.
As Philip said above 'the ground is controlled by the PCM' and if the PCM doesn't put out ground - like when the truck is off - then you'll see the 12V on both sides of the coil.
Interesting. The power to the coil must be supplied from the ignition, because when the ignition is off I only see +12 on pin 30. However, when the truck is running I see +12 on both sides of the coil, which must mean the PCM isn't supplying ground.
Does anyone know what conditions will cause the PCM to shut down the ASD relay aside from the crank sensor?
Blown fusible link....
The white one on my truck
Just under the hood coil spring. INSIDE the loom - unless someone's been there before you.
Find the white link - looks like heat shrink tubing - GENTLY pull the wires on either side. IF the is good you'll feel resistance if the link is blown you'll feel the give it. Mine also had a nasty looking black burn on the white sleeve - pretty much a guarantee the link is blown....
I just trimmed back the white cover and used a couple of strands of 16ga wire to wrap the two ends together - after sliding a piece of heat shring over one end. Wrapped the wire tight using long nose pliers, then slid the heat shring in place and lit a match to it - carefully.
No problem for the past 6 - 8 mos.
greenwing
Feb 23, 2006 09:36 AM
Superduty
18
Feb 16, 2006 09:25 PM
mazeppa
Feb 10, 2004 06:54 PM
