Rear diff Chatter
Old May 21, 2007 | 07:22 AM
gomerpile's Avatar
Different style posi. Ours will continue to move the truck even after the clutches are gone - it just acts like an open diff and there is a lot of slack.
well thats good to know
Old May 21, 2007 | 09:22 AM
dpuckett's Avatar
I had the exact same symptoms in a 92 way back when. I did the rear brakes, and noticed the diff fluid was burnt smelling, so I changed it and took a trip to MN (from CO). Seal started leaking, and within 2500mi, I had a spool on the back- I could NOT go around a corner, even on interstate, without it popping. I put new clutches in, along with a double dose of Mopr friction modifier, and all was well.
My mom now owns this truck, and it had grabbed around hard corners for a while. I sneaked some synthetic oil in there, along with the 2x friction modifier, and the grabbing stopped. Now if we can just find a place to stop the trnasmission chatter......
Try a full change with some friction modifier. Go for the good oil and modifier- dont get the Trans-X junk from AutoZone, et al.
DP
Old May 21, 2007 | 10:03 AM
gomerpile's Avatar
how well does something like Royal Purple run in these
Old May 21, 2007 | 10:17 AM
Barry St John's Avatar
If you want to run it for a while and do not need the limited slip you can try draining and refilling with amsoil or another slippery synthetic. As long as it's not howling on compression or load it is just worn clutches causing the chattering. If it's making any noise other than chatter in turns the bearings are on their way out as well and you will need to rebuild it soon. Good Luck
banana
Dec 1, 2009 11:44 PM
rigsy340
Sep 30, 2008 10:59 PM
Fenderstrat72
Jan 3, 2004 07:02 PM
Fenderstrat72
Dec 31, 2003 10:12 PM
Johnny
Dec 19, 2003 04:33 PM
