Random Vibration?
Old Jun 10, 2007 | 11:54 AM
Caver Dave's Avatar
Random Vibration?
While returning from the weekends adventure (tranny service, 3200 spring & VERY slight VE tweak), I have a frontend vibration that seems to be more pronounced when cool, than after warmed up. Maybe 20 miles into my trip today, it mostly went away, even though the road got rougher than the first half
It happens on both ultra smooth brand new blacktop as well as the older concreted surfaces, so I don't think it was road related. Nor does it follow speed, engine RPMs, or anything else I can figure.
-Tires? I know bias ply's will bump/jump until warmed up, but these are radials and it took 20 miles! I've had bad belts also, but it NEVER went away...
-Balance? Why would it go away?
-Steering or Alignment? VERY, very slight pull to the left, all links check visually (yanking back/forth while off the ground), and steering is tight (until 90 ), but vibrations aren't effected by turns or straight
-Wheel Bearings? I checked them last week when I had the frontend up and everything was tight
-Shocks? Appear to be Monroe's of unknown vintage...
If I'm missing something obvious or there are known issues... feel free to point me in that direction!
Old Jun 10, 2007 | 01:56 PM
pred's Avatar
Tire pressure even? try swapping the front tires with the rears and see if it goes away.
Old Jun 11, 2007 | 07:46 AM
Caver Dave's Avatar
I'd thought of that, but the tires are mix-matched Load Range wise (front = E & rears = D) and I really wanted to keep the E's up front. I agree that this would would further thicken the plot & provide additional troubleshooting data, but I can NOT figure why it would come & go like it is if the tires were "warped"?
Old Jun 11, 2007 | 11:20 AM
flashgordon's Avatar
slight loose lug nuts that tighended up with heat
Flash.
Old Jun 11, 2007 | 12:02 PM
Caver Dave's Avatar
All lugs on the front were freshly burped down weekend before last when I installed the sims... vibe was there both before & after the sims
Old Jun 11, 2007 | 12:16 PM
dpuckett's Avatar
Did you take an acorn-style lug nut and tighten two of them across from one another to line up the coins in the wheels with the coins in the hub?
For troubleshooting purposes, (unless you have 235s on the front and 215s on the rear) you should be ok to swap the Ds to the front for a while, at least til you get it figured out.
I will be watching this, as I have a similar vibration that is very random and unpredictable. But, between 78 and 83, it is quite smooth.
Daniel
Old Jun 11, 2007 | 01:02 PM
Rwinslow's Avatar
I used to have the same problem at 68 mph. Finally went away when I rebuilt the front end kingpins / balljoints.
Old Jun 11, 2007 | 01:54 PM
b.lee's Avatar
id get the front tires balanced on a "bubble balancer"
after the tires wear down they need to be re-balanced.
or if 1 weight falls off.
Old Jun 11, 2007 | 02:59 PM
Caver Dave's Avatar
Nope... the wheels appear to hub centric (no coned area in the rims) and the lugs are flat on the backsides. *if* this were the case, I'd suspect the vibes to be continuous...
I'm still thinking it's a balance issue too...
Old Jun 11, 2007 | 09:45 PM
dpuckett's Avatar
Is it a SRW or dually D350? The dualles had coined fit rims stock, but in 14 years, who knows what has been done or switched out.
Daniel
Old Jun 11, 2007 | 10:22 PM
Caver Dave's Avatar
Dually... that appears to be show room stock rim wise.
What do you mean by "coined"?
dodgedsl03
Jan 18, 2007 10:08 PM
BigBlue
Jun 16, 2004 04:24 PM
quantrill88
Mar 7, 2004 08:00 PM
gwhammy
Feb 9, 2004 07:10 AM
17
Jun 22, 2003 07:48 AM
