Radio Reception (poor)
Old Mar 10, 2006 | 11:46 AM
JD730's Avatar
I searched the archives hoping to find something, unfortunatly I didn't find anything.
This is one my 93.
I usually listen to the same radio station from home to work with no problems. I noticed it was degrading slowly, I wouldn't recieve that station in certain locations. Wasn't a problem, didn't bother me yet. It degraded even further, I figured the radio reciever was going so I put in a newer radio out of a 2002 truck. This was an improvement, however I still can't listen to the same station the whole way to work like I can with my 2000.
So far I've only replaced the radio. I have yet to inspect the antenna or its wire.
Suggestion or similar experiences would be great.
Old Mar 10, 2006 | 01:51 PM
wreckere022002's Avatar
Post ok
well on my 93 i put in a new wire and a after market raido this was last april i have had no problems with it so far try replacing the wire any local sound shop will have one for you keep me posted
Old Mar 10, 2006 | 03:52 PM
Pull the antenna out of the fender and clean the mounting surfaces. The antenna is grounded through the mount, reception will be poor if the ground is poor. Also could be the cable, I had that die on my old D250. It just pulled apart inside.
Old Mar 10, 2006 | 06:43 PM
JD730's Avatar
How hard is it to wrench the antenna apart, I don't want to mess it up too much.
Old Mar 10, 2006 | 07:23 PM
You're supposed to use a special socket, but a couple taps with a punch will knock it loose. Not too bad, worst case scenario is you need a new antenna for $20. Just mind the paint if the truck still looks good.
Old Mar 11, 2006 | 06:14 PM
JD730's Avatar
Thanks Dave, I found the problem, the inner conductor turned into nothing up by the antenna. Pulled a good one off the 91. All better now
Old Mar 11, 2006 | 08:28 PM
Bushy's Avatar
Patron Saint of 1st gens
Hey guys....do the radio's in our model year(s) still have the "tuner" on the back side...
The deal with that was, find a weak station and adjust this tuner till the station was as strong as possible...that "matched" the antenna and radio as close as possible....?????
I know, that's a REALLY old one right...
pb....
Old Mar 11, 2006 | 08:58 PM
That's exactly what had happened to my '85 D250.
Old Sep 26, 2010 | 09:09 PM
SORTIE's Avatar
Major bump
couldn't budge mine with my multitool, gonna try the punch trick next, Faith. Can anyone tell me if the mount is 1" 14-thread?
Old Sep 27, 2010 | 01:06 AM
Jim Lane's Avatar
pb....
I think the old "trimmer" went out when the tuner went digital, I still remember having to replace the vibrator.
Is there a socket on the bottom end of the antenna so I can replace the cable?
Old Sep 27, 2010 | 09:46 AM
roxxx's Avatar
This is one my 93.
YOU Can Hear your Radio ????
Sorry had too
Old Sep 27, 2010 | 02:03 PM
Hopefully JD got it figured out by now....4 years later. lol
SOhappy
43
Apr 28, 2006 10:38 PM
Stevenc
Nov 17, 2003 08:48 AM
Shovelhead
0
Nov 3, 2003 11:50 AM
gofastman
Feb 4, 2003 05:30 PM
Nevada
Dec 26, 2002 07:05 PM
