pyro's in
Old Jul 8, 2004 | 12:54 AM
swank's Avatar
pyro's in
went in pretty easy. seemed like it went a little deep though. not sure. did a search on egt's, sounds like anything less than 1000 or so(sustained) is OK. i'm seeing about 850 rolling at prolly 60-65 and about 4-5 psi. highest i got it to was +-1125. BUT, it took 2'08" to get TO 300. and everybody is saying not to shut down until below 300. i shut down at 300 and watched as it crept back up to 350 in about a minute. i guess i will have to turn the pump down a little? or just get 16cm? whadya think?
Old Jul 8, 2004 | 10:46 AM
Alec's Avatar
Did you put it in pre or post turbo?
Post turbo takes longer to cool down than pre-turbo (and longer to heat up, too).
Post turbo max is around 1000*, depending on your housing size.
Pre turbo max is less than 1300.
400 is getting too hot for shut-down. 300 is safe. 350 is okay . . . but cool down time is not really affected by your pump settings directly.
Old Jul 8, 2004 | 11:35 AM
jiMMyCTD's Avatar
my auto is prolly different but rolling down the road at 2000rpms doing 60 mine reads 650-700. 4-5 psi
jiMMy
Old Jul 8, 2004 | 06:14 PM
swank's Avatar
pre-turbo. sorry i forgot to mention that. thanks guys.
Old Jul 8, 2004 | 06:22 PM
The numbers you have look fine. You actually have room to turn the pump UP a little bit. The pyro is going to jump up a little after you shut down because the exhaust is cooler than the manifold. Once the exhaust stops flowing, the manifold heats the air/exhaust inside which shows up on the pyro. That's why you shouldn't shut off at 350 on the gauge, because the gauge is showing the temp of the exhaust, not the temp of the manifold/turbo.
Old Jul 8, 2004 | 06:43 PM
swank's Avatar
how about the high(?) cruising temp?
Old Jul 8, 2004 | 06:56 PM
jiMMyCTD's Avatar
stright pipe the air intake and upgrade to 7 inch exhaust, lol just kiddin, 4inch is cool. no restrictions = cooler temps!
jiMMy
Old Jul 8, 2004 | 07:08 PM
Not really anything to worry about. If it was over 1,100 steady that would be something to worry about.
Turning the pump up or down won't do anything for cruise temps, it still takes the same amount of power (fuel) to do 65 mph, so the temps won't change. If you want to lower it, the 16 cm housing will give you more boost and drop the temps a little.
Clay
Mar 21, 2003 10:53 PM
RAMTECH
Mar 9, 2003 12:49 PM
FiverBob
24
Nov 27, 2002 03:32 PM
bdog
Nov 5, 2002 02:09 AM
bkay
Oct 15, 2002 06:32 PM
